Gas smell!??!?!
mjmcbride1
mjmcbride1
Fayetteville, NC
Well, I do know that every time I drive it around (extended periods) and then I go to get some gas, when I remove the gas cap, there's always a pressure change sound. I can never tell if its exhaling or inhaling, but I can definitely hear the *whooosh* of pressure change.
ttkelly
You may also be getting fumes in from the fresh air vent or the heat air intake at the hood. Do you have seals on them and do they seal to the hood? You may try blocking them off with tape and turn your heater off then drive down the road and test it.
I had the same issue and a set of new seals is exactly the fix that worked for me!
