horsewpt69
So I'm in the middle of a ZF/NP205 swap and just hit a snag. The 205 yokes are 1330 and I had drive shafts made accordingly. Went out to install the new shafts and the yoke on the 205 is wider than the shaft side that meets the yoke. Measuring the yoke from bolt hole to bolt hole is 3 1/4" and the shaft measures 2 7/8" The width were the universal joint sits is correct at 3 5/8" with 1 1/16" cup size, so I know that it is indeed a 1330. Sooooooo WTF????
