- Jul 5, 2009
- 1,658
Trac-Bar has poly bushings and the bushings in the ends are tight. The sleeves in the bushings are starting to get loose, and the bushing to the bolt(s) are getting sloppy. My main problem is the axle end on the large "bolt". I imagine this was supposed to be welded from the factory when it was new (D44). Mine is broken loose and it feels like there are weld beads up in the cavity where the head of the bolt would seat.
If this is supposed to be welded, I'll do that, if it isn't, how tight am I supposed to get this to eliminated the play?
