4BTEB
This is what i have left. The price listed is without shipping, but will ship for actual cost of shipping. I can get pictures on request.. Thanks,
rear axle ubolt plates and old u bolts...$10
Under hood steering column hole cover plate...$5
Set of radius arms and caps....$50
Aluminum u joint clamps to hold driveshaft on new $15
2 Heater boxes ...$40 each
set of drum brake spindles and hubs...$40
2 track bars...$20 each
2 j shift t-case one good for housing.$20...one good just needs input shaft.$50
76 stock pitman arm...$20
70 manual pitman arm.... $20
manual steering box..$40
stock 70 steering linkage.. $40
set of window regulators... $30 Each
2 T/C cross members... $25 Each
taillight buckets... $25 pair
Coil cups .... $20 set
Tailgate Hinges and straps...$20
Door hinges...$25 set
Door straps...$15
Door latch Mechanisms... $30 set
set of 4 steel black painted wagon style wheels 15X7 ....$100
set stock hieght coil springs...$40 each
Metal Fans 2- 5 blade, 1- 7 blade....$30 each
misc. trim pieces....$Offer
plastic column bezel...$10
Folding truck mirrors....$30
Doors with window frames removed, I also have window frames, no glass, can see in pictures....$300
Hood prop rods........$10
I may have a couple of other things... I'll post pictures. If you see anything in the pictures ask.
I think this is everything I have left i will post if i find something else...
I posted pictures post #187-190!!!!!
Door straps...$15
