Axle Splines
wal1210
Newbie
I pulled my axle out this weekend so i could change the wheel bearing, drums, and wheel studs and found that my axle splines look to be a little worn. Is this wear normal and are these axles safe to put back or should they be replaced?
Apogee
I would say that looks pretty normal. No twisting is good, so maybe better than average.
Pa PITT
Stephenville TEXAS
... I'm going with Normal also.. They are not twisted & they still have the Etching ..
If you fixed it you'd want to put in 35's then you'd have to swap gear in the sides of your Pumpkin.
Rustytruck
Do the math on replacing the complete axles. You will probably find using new steel over 50 year old sub par fatigued steel might be the better move.
sprdv1
REBEL
If you abuse it much, may be time for replacement, otherwise should be good for normal use :)
Apogee
What's the intended use? Street/trail? Tire size? Gear ratio? Engine/trans? If the end goal is to be able to do some moderate wheeling and not break axles, then I would look at a 31-spline upgrade...but do you have a big-bearing or small-bearing housing? These things tend to snowball, so before you get talked into building a 40-spline trophy truck rear end, let us know what your goals/plans are for the rig.
Viperwolf1
electron whisperer
I'd run it. It looks like you have a limited slip diff in there from the double set of spline engagement.
W
wal1210
Newbie
The vehicle is a 77 with a large bearing axle. Currently running a 302 and c4. Yes, it does have a limited slip differential from the factory. Ultimately, the vehicle will be mostly a street vehicle with some very light offloading. I've been upgrading little things here and there in an attempt to make it road worthy, although when I have some more time and money, the vehicle will likely undergo a frame off restoration. So, i'm stuck between making it roadworthy now and reusing parts that are not too worn, or shelving the whole project until I can afford to do everything once with upgraded components.
blubuckaroo
Grease Monkey
Ridgefield WA
Thought the same.
The factory Ford limited slip is really a POS!
It actually uses the first 1/4" of those splines to drive the whole axle.
That's where the failure normally happens. Some call it a broken axle, but it's really just stripped splines.
With an open rear, those splines would last much longer, because they have a full inch of engagement with the spider gears.
Either way, it has been working and by all accounts there is nothing different so it should continue to work just fine for a long time. Parts are not damaged and no reason to expect them to fail in any reasonable amount of time. From the looks of the 40 year old parts, they will last another 80 years before you might want to consider something different.
Viperwolf1
electron whisperer
Thought the same.
All the factory '77 trac loks I've seen are 4 pinion (4 spider gears). That is a big strength improvement over the earlier 2 spiders. The axles spline to the side gears, not spiders.
blubuckaroo
Grease Monkey
Ridgefield WA
My '77 stripped off the spines and ruined the spider gears at about 80k miles. I was travelling from SOCAL to Transport OR and it died in Redding.
I pulled the rear driveline and drove to Toms (then Ted's 4X4) for a replacement third member and axle.
Toms saved my salmon trip!
sprdv1
REBEL
all a matter of having the time right...
Apogee
Not to hijack the thread, but where in the heck is Transport, OR? Been here my whole life and never heard of it. That said, good job getting over the Siskiyou Pass in front wheel drive...that's a good reason to run a good front shaft IMO.
blubuckaroo
Grease Monkey
Ridgefield WA
Uh
Darned phone did that.
I was salmon fishing out of Reedsport OR.
And YES! I feel It's important to keep the front "highway" friendly. What i mean is, It's important to check and correct your front pinion angle after any chassis lift or castor change.
