Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 07/10/11, 01:05 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Arrow Panhard Parts & Kits from Ruffstuff!
We make 4 different Panhard / Trackbar brackets and I get alot of questions as to why not just one?
Here is the simple answer. You are either replacing a weak factory bracket that has broken and need something stronger and more versatile or you are swapping a new axle into your rig and need something that works better or is more adaptable!
We make 2 for the axle end and 2 for the frame end. In this pic, from the top left (going clockwise) we have the Axle Offset Bracket because 70-80% of the time you need the additional room on the axle. Next we have the Axle Centered Bracket for those of you that can work with one, both have 3 height adjustment positions. The lower right shows the Frame Outside Bracket for those of you going full width and to the left the Frame Inside bracket for the relatively stock width axle. The Frame brackets both have 2 mounting positions so matching up is easy.
Remember, Selection is always the key! We have been making these for 4 years but I don't think I ever posted these here...No time like the present!
We also make the complete kit with the DOM to keep the cost down for you! http://www.ruffstuffspecialties.com/catalog/PANKIT.html
Dan Fredrickson 916.600.1945
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 07/20/11, 10:28 AM   #2
Gravel Maker
Quick with a Laser!
Sacramento
Time to think twice! When going full width you need to change the panhard to a wider option, we give you options
Old 07/29/11, 03:01 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
This will take the abuse
Old 05/22/12, 11:49 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Definately time for an update! Stronger is better
Old 05/31/12, 12:17 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Is it time yet?
Old 06/02/12, 02:22 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Do you need a new panhard? Did you add lift and big tires? Did you do anything to the panhard? If you are still running the stock you need one...
Old 07/30/12, 02:21 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Get it done the right way!
Old 08/22/12, 05:30 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Time to straighten out the wander...
Old 09/25/12, 09:05 AM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Such a great choice!
Old 10/29/12, 08:11 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Can never go wrong with a panhard!
Old 07/12/13, 03:40 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
When you want the right stuff, think RUFFSTUFF!
Old 07/31/13, 09:36 AM   #12
Gravel Maker
Quick with a Laser!
Sacramento
We have what you NEED!
Old 08/06/13, 09:53 AM   #13
Gravel Maker
Quick with a Laser!
Sacramento
This weekend was awesome, thanks guys!
Old 08/21/13, 08:07 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Can't go wrong with one of these!
Old 09/25/13, 09:51 AM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Tough to beat, quality & price all in one!
Page generated in 0.32501 seconds with 61 queries
