conor_nolen
I am a new Ford Bronco owner (1974) and trying to figure out how to manage dual tanks and gauge the level of each tank accurately. I have a fuel tank switch below the driver seat and it appears to operate effectively but does not impact the level of the gauge when switching between tanks.
Questions:
1. Should I use rear as my go to tank and lean on aux front as a back up only when needed? Or should I use them both equally?
2. Should my fuel gauge be reading the collective level between both or Change based on the tank I have selected?
3. Is it worth while to upgrade to a single, larger rear tank and remove the dual tank setup altogether?
Thanks!
Questions:
Thanks!
