Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 09/13/17, 07:32 PM   #16
5001craig
5001craig's Avatar
Stock is what you make soup with.
NE Indiana
eBay: 5001craig
Originally Posted by Green_Bastard View Post
Ok I've got it narrowed down to either Mickey MTZ P3s or Maxxis RAZR MTs. Thanks for the help guys
Mickey MTZ is available in LT315/70R17 (35x12.5) Load range E that weigh 68 pounds. Not too heavy and a lot lighter than mine at ~94 pounds. Seems pretty light for a Load range E tire.
Maxis has a LT315/70R17 (34.6" tall) Load range D that the weight is not listed on their website but should be reasonable or less than the 68 pound MTZ's. Might be worth a call to them to see what they weigh.
I'm wanting Load range C so I will probably stick with 15" rims.
'74 Explorer 408W/C4/Atlas 3.0/35 spline rear/discs & Grizzly's front & rear/Duff Monster 3.5" with 4-Link Rear/2" BL/Painless...
My build thread.
5001craig is offline   Reply With Quote
Old 09/14/17, 12:07 PM   #17
rpmgarage22
Builder of all things controversial
Clinton, TN
Maybe an outside version of an "inside scoop"? My dad and uncle just retired from 42 and 38 years, respectively, with a major tire company that still builds tires in the US. They no longer build auto tires at their plant, but Dad designed a few tools that are used almost worldwide, so he keeps "in the know" when he can.
That having been said, never believe anything I say...check it out when you can.
So, those tires are made in China, by a company owned in Taiwan (Federal Tires). They were originally built on an anticipated contract with Discount Tire Company, but continually failed QC and could not pass Discount Tire's standards. Even though the DB TV show makes it look like they came up with the name, the tire was already branded as "Patriot".
When DT stepped away, the company approached Pep Boys/CSK. Again, could not pass minimum standards and were told, "No thanks."
Then, through the magic of TV, they became an "awesome idea" to the guys at DB. The marketing match was made, Hollywood had their say, and the SAME TIRE is now the DB "Patriot" series.
Although it IS true that they developed a "special compound" for the diesels AFTER the deal was made, the other tires are the same ones that everyone else rejected.
This series of events took several years to pan out.
So...I'm saying that to say this...BUYER BEWARE!
If you do go with these tires, demand that the seller prove the provenance by getting the build code from the tire (Last four characters after DOT code. For example "0317" equals the third week of 2017.). If the build code is before 0616, I would not take them for free. The rejection notice came from Pep Boys/CSK in late 2015, I believe. Can't verify on Discount Tire.
Final opinion, again...just an opinion: There are some very good tires coming out of China. The issue, as with everything from that region, is how good the US quality control is for that product. The tires that Discount Tire are having built in China are really good tires. Some of the tires that Tire Rack sells from China are not... The big difference is that Tire Rack is basically a distributor, while Discount Tire is actually having tires manufactured for them under private label.
rpmgarage22 is offline   Reply With Quote
Old 09/18/17, 09:05 PM   #18
Green_Bastard
Green_Bastard's Avatar
Parts Unknown
Castle Rock, CO
I ended up ordering the Maxxis tires. I really like the way the look, the reviews are great and the guy at 4 Wheel Parts had good things to say about them. They came in today and I checked the weight, there 10lbs heavier than the MTs at 78 lbs.
Green_Bastard is offline   Reply With Quote
Old 09/18/17, 09:07 PM   #19
Green_Bastard
Parts Unknown
Castle Rock, CO
Great info! Its interesting what you can find out when you know the right people. After more digging, I did find lots of negative info and decided to go another direction.
Old 09/18/17, 09:50 PM   #20
roundhouse
Lost in space
I will never have time on any vehicle I own that were made in China
They are commies who enable and support the nutjob in North Korea and the quality of anything made in China is lousy
One thing if it's a raincoat , but no way will I ever trust a tire made in China
They can't even make dog food that doesn't have lead in it
"Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?" [Alan Keyes]
For some, Freedom matters, for most, prosperity suffices. [Fred Reed]
EFI, NV3550
roundhouse is offline   Reply With Quote
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.29599 seconds with 55 queries
