posting my build with pics
zenadog
St. Louis mo.
I want to post pics of my bronco in progress, can I post them from my cell phone, and if so how? any instructions would be appreciated. I did pay my 12 bucks to start.
krdale
Newbie
Norway
Hey, you can easily do this with tapatalk pro, I have just done that with some photos to illustrate how. But my post is pending admin approval (not sure what that is) so should show up at some point.
krdale
Newbie
Norway
Otherwise to post within a web browser on your mobile you need to upload the photos separately and then link the url (web address of each photo) manually.. so better use an app
krdale
Newbie
Norway
Here’s how it looks like in the app, so you just hit the plus sign on the left and it lets you upload photos from your phone album.
Sent from my iPhone using Tapatalk Pro
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Yes, you can upload directly from your phone if you're a Contributor, which you did sign up for. (Thanks!) You upload them the same way you do using your computer. (instructions here) You can either pick photos already on your phone or take them as you upload.
You can also use Tapatalk as krdale suggested. The only issue is that then the photos are hosted on Tapatalk, not here on the site. So if Tapatalk ever goes away or changes their policy or pricing structure the photos will be lost. (like Photobucket did last year which wiped out hundreds of thousands of photos hosted on forums all over the web)
Photos taken from phones do have an issue with rotation control though. See my example below.
admin
Administrator
Phoenix, AZ
Not true if you're a Contributor. You just upload directly to the forum. No need to link the URL manually.
krdale
Newbie
Norway
Oh nice, how would you do it? When I try I get asked for a url.
admin
Administrator
Phoenix, AZ
Sounds like you're maybe using the "insert image" button rather than the "upload photos" button. To upload directly to the forum (as a Contributor) you need to be in the "go advanced" edit mode. Here are instructions. The screen shots are from a computer, but same concept from a phone.
http://classicbroncos.com/forums/showthread.php?s=&threadid=34373
The one part that's a bit clunky is that on some phones the "upload" popup window doesn't close after you upload photos. So you have to close that tab or switch back to your original posting tab and finish writing your message there.
Crawdad
I have found this to be a problem using my Apple products (iPhone, iPad, iPad mini). My picture looks fine until after I upload it to this website. It turns out sideways in almost all my pictures. I have found that if I edit the photo to “square” it always posts correctly. Go to “Edit”, then hit the hi lighted grey box on the right of my first pic, then go to bottom and tap the box that looks like a bunch of small frames. Tap it and a menu will display, tap “Square” and picture will adjust as you can see in pic 2. Hope this may help someone out there. Matt
