Aptosgrown
Looking to take advantage of the sales this time of year and hoping to get ready to re-do my brakes and add a hydroboost in a month or three. Need some help with brake lines and kits. I have never fully re-done a brake system, just pieces.
Current setup is '69 dana 30 up front with drums all around and stock brake system (no power assist). I plan to run all new brake lines/hoses, mine are crusty, rusty and hoses are cracked. Install a astrovan hydroboost and MC and keep the drum setup (residual pressure valve will be needed) until I have the funds to swap to a dana 44 and disc up front. I have the astro HB, flush firewall mounting plate, and will be getting a new astro MC. I know I will have to figure out AN fittings and hoses in the future.
How would you take care of redoing the brake system (No I am not interested in disc at this time or other power brake setups). I am inclined to buy the full brake line and hose kit from Toms or another sponsor. However, I would assume that the stock steel lines from the proportioning valve to the Astro HB & MC would be different than the original stock lines, different distance and location due to the HB and would not work?
With all of the knowledge on here I am hoping you guys can point me as to:
Do I buy a full kit and lines can be bent a little, or forgo the kit?
Should get Stainless lines? What's the benefit?
Should I get stainless braided hoses from hard lines to backing plate due to the increased power/pressure?
What other parts pieces?
What makes this job easier, tips and tricks?
Thanks for all the help guys!
