- Dec 29, 2010
- 1,768
I cannot wait to show you guys the brand new Exhaust kits we have been putting together!
I know looking cool is VERY important in your EB but sounding cool rates right up there TOO!!
I also heard that James Duff is so excited about them he's going to be offering a super special deal on them for Black Friday!!
While you're sitting there marinating on that let me tell you some of the changes we've made.
Our 4 piece kit plus 2 mufflers (4 different options)and hardware now comes as 6 pieces. Why is that better?
-can ship in a smaller box which saves you more money on shipping
-tail pipe can slip off and be left off for those trips you want to go off roading and don't want to destroy it.
-you have the option of choosing a tail pipe that comes out at a 90° or 65° angle. Neither function better it's just a preference of looks.
-running James Duff long arms, Torque Tamer, larger gas tank or 4" rear bump stops? No problem! Our new kit works with all of that!
-302, 351W, stock or HD motor mounts? Yep works with that too.
- You have James Duff Long tube headers or stock exhaust manifolds? Also doable. If you have the stock manifolds just buy our exhaust manifold extensions part# 3091 and you're set!
-this kit works for mild to wild setups with 0-3" of body lift
-think you need a shop or a welder to put this on? Think again. with a drill some sockets and at the very least will acknowledge the instruction sheet exists you can put this on in your driveway ;D
Disclaimer:
-Our exhaust kits will NOT work if you are not using a Dana 20 transfer case
-if you're NOT using James Duff long tube headers we cannot guarantee this kit will work for you w/o some modification.
-if you are running shorty headers you can run this kit but you will need to have extension pipes made.
-we do NOT offer this kit in stainless steel.
-if you buy this kit with 40 series flowmasters the exit pipe will require 1" of tube trimmed off. Easy task for most but if you don't want to make the cut just buy the kit with Vortex mufflers. Same sound and quality plus it's less expensive and easier to install.
Here is the link to the website
http://www.dufftuff.com/Dual_Exhaust_66_75_Early_Classic_Bronco_Aluminized_p/3095.htm
Here is a quick video of me walking around the show chassi at James Duff showcasing how the new exhaust fits. The sound you are hearing is the new exhaust with our Ceramic Long tube headers, the new exhaust system and a pair of cherry bomb pro mufflers.
The display chassis is showcasing two different mufflers we offer as well as the two different tail pipes we offer.
https://youtu.be/EfTaEcOJwyA
Disclaimer:
