- May 27, 2010
- 233
Hey guys,just got done with wh 1" body lift and hooked back up everything but a bit confused on the clutch rod,now the vertical rod under the pedal is a clutch rod correct? Also there is a horizontal rod with threads and two nuts is that called a clutch rod as well or adjustment rod? I struggled a bit trying to hook the vertical rod back up and then put the cotter pin in but i got it does that struggle mean i need to get a different length vertical rod and is that vertical rod the only adjusting i need to do or do you also need to adjust the horizontal rod as well? Thanks for any help! rich
