Tire Carrier Mounts
fosgate150
So I was mounting the tire carrier mounts and it just killed me to have metal on metal, fresh paint on fresh paint. I took some of the fender flare welting and put it along the side and across the top edge (it is one piece with relief cuts for the corners). Its kinda hard to see in this picture...
Has anyone else thought of something else? rubber, tape, sealant...
Crush
Greenbottom, WV
Ive thought bout it and man that looks good. Mow put some stainless button head allen key or star bolts in there to tol it off
kip60
I like the idea of allen head bolts instead of having large heads sitting there. The paint kind of conceals these tho...
ep67bro
Bronco Junky
Easton, MD
Looks good. Years ago when I had my stock Carrier on my 67, I put a thin foam between the carrier and body. It did a good job of protecting the paint. Years later I removed the stock carrier when I built my own bumper to hold a 35" spare, paint cleaned up good. I don't think I could put metal on metal!
NicksTrix
clear helicopter/paint protection tape on the inside of the mount
Rickb1b
Looks good. I’ll probably do the same thing. I like the idea of stainless steel Allen head bolts.
fosgate150
fosgate150
stainless..
Ok, I put some stainless button head allen bolts in to see what it would look like... What do yaw think?
Gweiner
Charlotte
Looks great! Not to hijack this thread but has anyone figured out a way to reinforce the factory tire carrier to hold larger tires? I read on here that the added weight is bad for the rear quarter panel. I would like to keep mine stock with a 31 or 33" tire and not do any damage driving off-road with the stock carrier.
Crush
Greenbottom, WV
Prolly wouldnt be too hard to build an arm out of sqare tube that comes off the rrame and goes up into the tail light housing and has the spare bolt to it. But then you woukd need the connection to the frame to have a poly bushing in it or something to allow for body/frame flex
