If it's a thread that deals with a 1966 Bronco, as far as details, quirks, oil baths, oddities, deletes, threads with original pics, 66' restorations that we can use for references, etc............ I've tried to find some major ones and list them here. If you see a thread I've missed, post it up so I can add it, thanks.
I'm sure I've probably missed some restoration back to original threads, post them up if I missed you. Hopefully it will be a continuous project, adding things as we come across them. It will be nice to have all/most of this info under one roof! ;D
If you've got an original or restored to original, post up some pics........we can't have enough reference pics IMO!!!
Quirks...
Rarest 66' Parts
66' Body Differences
66' Unique Features
66' Only Options/Specs
66' Air Cleaner
66' Vin Badge Location
Earliest Serial Numbers...
Earliest Bronco Built
Earliest Serial Numbers Known to Exist
Restorations......
Blue Bastards u13 Build
Taking 66' Back to Original
kcmiller 66' paint/parts Questions
http://classicbroncos.com/forums/showthread.php?t=258923&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=258930&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=258285&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255971&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255131&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=251129&highlight=1966+bronco
http://classicbroncos.com/forums/sho...ht=iowa+bronco
http://classicbroncos.com/forums/sho...d.php?t=164247
Window Regulator Repair
Window Regulator Shaft Replacement
Steering Column Wiring
http://classicbroncos.com/forums/showthread.php?t=280664
66' in general conversation threads.
http://classicbroncos.com/forums/showthread.php?t=271539&highlight=great+66'+thread
http://classicbroncos.com/forums/showthread.php?t=257544
http://classicbroncos.com/forums/showthread.php?t=261757
http://classicbroncos.com/forums/showthread.php?t=250005&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255000&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=258012&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=262358&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=262606&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=262418&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=262102&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=262033&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=261930&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=261496&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=253626&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=259086&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=258751&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=258742&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=256491&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=256065&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255445&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255609&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255598&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=255032&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=253843&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=221913&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=250849&highlight=1966+bronco
Eyebrow Grill
Eyebrow Grill ID
Mirror Threads
http://classicbroncos.com/forums/showthread.php?t=260503&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=250996&highlight=1966+bronco
http://classicbroncos.com/forums/showthread.php?t=266504&highlight=1966+mirror
http://classicbroncos.com/forums/showthread.php?t=96704&highlight=1966+mirror
http://classicbroncos.com/forums/showthread.php?t=267682
Dash/Door Panel Color
Bronco Gray Poly
Hub Cap Threads
If you're looking for 66' hub caps, and you question whether the front caps are legit Bronco caps or cut Mercury, look at the tabs on the back. Bronco caps will have the tabs in sets of 3, whereas the Mercury caps will have tabs evenly spaced all the way around. Bronco front hub cap is below.
http://classicbroncos.com/forums/showthread.php?t=230526&highlight=1966+hub+caps
http://classicbroncos.com/forums/showthread.php?t=224982&highlight=1966+hub+caps
http://classicbroncos.com/forums/showthread.php?t=190564&highlight=1966+hub+caps
Quirks...
Rarest 66' Parts
66' Unique Features
66' Air Cleaner
Restorations......
Eyebrow Grill
Eyebrow Grill ID
Mirror Threads
Bronco Gray Poly
Hub Cap Threads
