BUSY... Has anybody noticed that a D60 is HUGE! : )
Goal: D60 install- narrowed to 65" WMS or less
- stuffed! I want 6" of uptravel with 16" ORI's
- stuffed! I want it to fit with less than 3 1/2" of suspension lift
So the D60 was previously narrowed 6" on the pass side only, the pumpkin hits about 5" of the oil pan when centered under the frame... : (
So it looks like I need to narrow the DS and add tube on the PS. After stuffing, measuring, determining what I want for WMS (mainly how much tire I want out of the wheel well) I really hate mud flying inside on the dash/gauges/me/wife/ etc so I'm trying to keep this as narrow as possible and still allow FULL lock to lock turns with 40" tires....that ended up being the hardest part!
Here I'm measuring to see how much I have to narrow the driver side to able to stuff the pumpkin between the differential, the motor mount and the frame. I ended up cutting off 2 1/2 inches and leaving just enough width to be able to weld on the radius arm mount
Here is a CB Link I had running simultaneously to a mini "help me" thread I started trying to find a way to make the D60 fit...
https://classicbroncos.com/forums/showthread.php?t=275875
