    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
SOLD Smooth Shift Collar For Floor Shift Conversions (Stock 66-77 Bronco))
Status
Not open for further replies.
operator23
Fredericksburg
smooth collar
I am replacing a manual column on a 66 that had already been converted to automatic floor shift. Do you still have any smooth collars left? if yes, how can I order/pay for one?
I am thinking I need #1 but this is my first time dealing with steering column so any advice/input you have would be appreciated.
operator23
Fredericksburg
The collar and turn signal switch mount replaces your stock gearshift collar and turn signal switch mount when you go to a floor shift. If your column is an automatic you need both the turn signal switch mount and the smooth shift collar (2 or 3) $25. Your automatic turn signal switch mount does not have the mounting holes for the collar nor any room to drill them. I have turn signal switch mounts for both emergency flasher switch on the column (3) $25 and for the early ones that either don't have an emergency flasher switch or the switch is on the dash (2) $25. If you have a manual shift column now you can reuse your switch mount and save on shipping and the cost of the switch mount. The collar only is(1) $20. All collars and switch mounts need to be painted. The factory paint has a lot of defects either from wear or quality of the original paint. Pictures are sample only. You probably receive a color other than black. Shipping for all 50 states is $12.45 or less depending on zip code for both the collar and the switch mount. If you need only the smooth collar and mounting screws shipping is $7.15 or less for all fifty states.
I also have other small parts that go between the steering wheel and upper bearing if you need them.
I HAVE A BUNCH OF EACH.
rebuilding a manual steering column on my 66 that has already been converted to auto floor shift and am looking for a smooth column. do you still have any? If so how can I order one? Also this is my first crack a rebuilding a steering column so any advice/input you have is appreciated.
Status
