agboy91
I have some parts remaining from a recent 72 & 76 bronco rebuild that I need to sell so I can clean the garage and buy some new parts. Let me know if your interested. If you see something you may need, PM me with an offer. Thanks.
1. 3 speed trans - $200
2. Clean air/heater box 2 - $50
3. 2000 explore rear axle 2 - $200
4. 76 PS pump - $50
5. 3 speed adaptor - $50
6. 76 dash harness - $75
7. 3 door skins removed for patch work- $25
8. Front coil springs 2" lift - $100
9. Main fuel tank no leaks - $125
12 Original steering column manual - $125
13. Original hood rust holes on front, good for trail rig or add nose cover - $100
14. Hi Pinion D44 axle from a '79 F150 no shafts or steering components, - $250
15. NP205 rear yoke-$50
16. Inner shift tube for manual steering column - $25
19. 4r70W AOD out of a 2000 explorer 2wd $200
20. T case handle T shift and lever linkage $50
21. Clutch linkage $50
22. Old wire harness. $50
23. Original Front drive shaft - $75
24. Original Rear drive shaft - $75
25. Throttle linkage - $50
26. Stock Distributor - $40
27. 302 oil pan- $75
30. D44 drum brakes w/backing plates (pair). $30
31. Original locking hubs (pair). $40
32. Stock hubs (pair). $40
33. Stock spindles (pair). $40
34. Voltage regulator w/ stock alternator wiring harness. $10
35. Throttle linkage mouse trap $45
36.. Plug wires. $10
37. Coil. $5
38. Distributor and cap. $30
41. Aux fuel tank with new sending unit. - $100
42. Dual groove water pump pulley - $40
43. Clutch peddle linkage - $50
44. Sold- Powered By Ford Valve Covers - $40
45. Explorer fire wall bulkhead connectors, male and female, $30
46. Original Amp guage
4. 76 PS pump - $50
37. Coil. $5
