Thread Tools
Old 09/16/18, 06:52 AM   #1
BGBronco
BG, KY
Inner kick panel nuts / Door limiting strap hardware 'stripped'
The nuts used to attach the door limiting strap hardware to the inner kick panel are stripped on my bronco. What is the easiest way to solve this problem and get the hardware attached. Thank you.
76. 302. C4. 33". PS. PDB. 2.5" Lift.
BGBronco is online now   Reply With Quote
Old 09/16/18, 08:28 AM   #2
tatersalad
tatersalad's Avatar
Placerville
You may be able to run a tap or thread chase through them.
"The test of the morality of a society is what it does for its children" Dietrich Bonhoeffer
351W, EFI, C4, Explorer Rad, Taurus fan, 33x12.50
tatersalad is offline   Reply With Quote
Old 09/16/18, 09:59 AM   #3
langester
MASTER OF MADNESS
langester's Avatar
There are Very Few problems well placed ordinance won't solve!
Cortez, CO
If they are stripped out very bad you could jump up a size in bolt and drill and tap them. You will have to drill a larger hole in the strap plate too but I think there is plenty of steel there.
Good luck!
1972 Bronco "Spawn Build" still in progress.
langester is offline   Reply With Quote
Old 09/16/18, 02:00 PM   #4
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
I used nutserts to repair mine.
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is online now   Reply With Quote
Old 09/17/18, 05:55 AM   #5
BGBronco
BG, KY
perfect!
Thread Tools
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.29109 seconds with 62 queries
