Thread Tools
Old 09/16/18, 08:23 AM   #1
Banjer Picker
Banjer Picker's Avatar
Man, you looked like you were FLYING...when I went around you!
Dallas
eBay: Sonvolt76
Did I Kill my hydroboost?
Accidentally reversed the pressure hoses to my astrovan hydroboost unit.
Routed the hi-pressure hose from the pump to the high pressure OUTLET on the HBoost unit instead of the inlet side.
Never could get it to bleed (obviously). Went through the whole bleeding procedure a couple times, drove it around the block a few times before I discovered that the hoses were reversed.
Swapped the hoses to the correct way and now I still canít seem to get it to bleed. Even with the hoses routed correctly the steering has almost no assist and a funky brake pedal. The pump wines like crazy and spits fluid through that tiny hole in the cap too.
I know all of theses are signs of air in the lines but Iím wondering if killed the hydroboost when I put it through a workout with the lines reversed.
Any thoughts or similar experiences?
Side question: Should that small hole in the cap just be a open port? Seems like it would have a screen, or something that would all air to escape but not let dirt/debris in.
Banjer Picker is offline   Reply With Quote
Old 09/16/18, 09:58 AM   #2
Banjer Picker
Dallas
eBay: Sonvolt76
I was also going to disconnect the high pressure hose where it goes in to the HYdroboost and crank the truck to see if the pump is working properly. Visually, what kind of pressure or volume of fluid should I see coming from the Saginaw pump?
Old 09/16/18, 02:03 PM   #3
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
Hydroboost should be fine. I did the same thing and ran the lines backwards. Drove it for a couple of days and couldn't figure out why the brakes sucked. Swapped them around and it stops on a dime. No damage done.
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is online now   Reply With Quote
Old 09/16/18, 09:02 PM   #4
Banjer Picker
Dallas
eBay: Sonvolt76
Thank you for the feedback
Old 09/16/18, 09:10 PM   #5
Banjer Picker
Dallas
eBay: Sonvolt76
Small update but no improvements.
Disconnected the high pressure line from the steering pump at the hydroboost and had my wife crank it to see if it was pumping. Seemed to be moving a good pit of fluid but it also seemed a bit irratic and not in the solid stream that I would have thought. Reconnected it to the hydroboost.
Took the high pressure line off at the steering box and had my wife crank it. A good bit of fluid came out here too so the fluid does seem to be making it all the way to the box...
I then had her press and hold the brake pedal with it running a NO fluid came out of the high pressure hose. That doesn’t sound like it’s right.
Thoughts?
Old 09/16/18, 11:52 PM   #6
Banjer Picker
Dallas
eBay: Sonvolt76
Ok, think I got it knocked out. Update tomorrow.
Old 09/17/18, 12:16 AM   #7
DirtDonk's Avatar
San Jose, CA
'Ya big tease!
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 09/17/18, 09:10 AM   #8
Banjer Picker
Dallas
eBay: Sonvolt76
Originally Posted by DirtDonk View Post
'Ya big tease!
Lol. The truth is that I didnít get to drive it around the block for for the official test but steering was SO much better.
I spent 3.5 hours going through that tedious bleeding process of cycling steering, adding fluid, letting he air bubbles settle, checking for leaks.
Iíve bled the steering/hydroboost system in my bronco at least 6 times in the 12 years Iíve owned it and it has never required more than about 20 minutes to get it in at least drivable condition.
Even when I did my 4x4x2 conversion it didnít take NEARLY the effort!!
Iíll test drive after work today and report back.
Thanks!
Old 09/17/18, 09:36 PM   #9
nvrstuk's Avatar
20 gears forward...no reverse!
WA
Takes me about 3+ hrs to bleed my P/S system with the hydroboost... can't hurry it.
Hope it works for ya!!
Strrroker powered... 418 cubes, 518 HP, SEFI, EDIS, Still 20+ forward gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607 NWCB Stroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build: http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline   Reply With Quote
Old 09/17/18, 10:26 PM   #10
Banjer Picker
Dallas
eBay: Sonvolt76
Test drive went well. Seems to be
operating back to normal. Weíll see once I get it in the trail.
Thanks gang
Thread Tools
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.35937 seconds with 62 queries
