laserfish
- Feb 19, 2015
- 122
In trying to run cooler than 220 in heavy traffic I thought I would purchase a new shroud since I had the 7 blade stock fan up in the attic. Been running a 12 inch Spal electric puller just up against the radiator with no shroud. Also have a Flowcooler water pump. The fan is still about 1/2 to 3/4 of an inch from even being level with the shroud and at least an inch to inch and a half from being inside the shroud like it should be. Been way to long since I put the electric on to remember how it looked originally. I do know I cored the radiator with the aftermarket flex fan in high water so I know it was closer than it is now. Anyone know what might have caused this? Do they make longer spacers to go between the fan and water pump? This really caught me off guard. The good thing is I found where the radiator is leaking. Fix that and I may be whistling in the wind here.
