Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/14/12, 01:49 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Smile The Ruffstuff 4 Link Kit!
First off I should explain my thoughts so this dosen't sound too strange to you guys.
A few years ago I started seeing brackets that completely disregarded all the rules about Link Suspensions as we knew them to be. The changes that have come to be accepted as the way to do it no longer care about seperation, not vertical or linear. Did those rules change overnight? No, they didn't. What changed was a few companies saw a way to make things easier, for them and the many people that bought into the idea. Now every company making anything for link suspensions has these. Why don't we?
We do not make a combination upper/lower link bracket with 4" (or less) of vertical seperation and no inches of linear seperation. I simply do not agree with it. It certainly makes installations easier but it also limits you to only what you can do using that type of bracket.
Our Link Brackets are not holding you to any pre-determined limits. Our Link Brackets ALLOW you to make your rig work as well as you can design it. Not limiting you in any way. They are not shaped to be pleasing to the eye, they are shaped to give the broadest mounting area which is a much stronger way to do things.
I know I am going to get some flack for this but I believe everyone is entitled to an opinion and this is mine. Anyway here they are, our new 4 Link Kits!
For Framed Rigs
This is it, everything in one package for a great price, and not low end stuff just to be cheap either! The kit is wrapped around 8 of our 1.25" Heat & Cryo Treated 78,000lb+ RSL Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs. Not a cartridge type joint in sight and not 7/8" uppers as is becoming common among companies just wanting to have a low price. If you want 7/8" uppers we can swap them out for a lower price but I would remind you torque transfers throughout the system, the only difference is the uppers do not take impact.
The Upper Frame brackets are our 25 degree 5 way Adjustable link brackets. The Lower Frame brackets are our venerable Chassis Link brackets, time tested and proven for optimum performance. All of our lower brackets are ramped for protection.
For the axle end we have our Axle Mount Link brackets and our New Truss that we have refined for additional strength while shedding uneeded pounds. On the Truss we keep it simple with 4 of our 3/8" thick Flat Bottomed Link Tabs. The truss is an option that you can choose to leave out for a $100 savings.
For Tube Chassis Rigs
Everything on the axle is the same as the other but the tube side is different.
The Upper Chassis brackets are our 10-35 Degree 5 Way Adjustable Tube Mount Link brackets. The Lower Chassis brackets are 10-35 Degree 3 way Adjustable Tube Mount Link brackets for optimum performance.
The only choice you need to make is if the Truss needs to span a Large third member (D60, D70, 14 Bolt, Sterling, Eaton, Dodge 9.75, etc...) or a Medium sized third member (Ford 8.8, D44, Ford 9", Toyota, etc...). If you want to make more changes give us a call and we can see what we can do!
All kits can be changed to be exactly as you wish, just give us a call
http://www.ruffstuffspecialties.com/catalog/34LINK.html
Dan Fredrickson 916.600.1945
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 08/28/12, 12:49 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
Thumbs up The Ruffstuff 4 Link Kit!
The right way to do it !!!
Old 09/05/12, 12:36 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
Time to get in the with the big kids
Old 11/14/12, 09:50 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Linking it up really is not that big of a challenge, not like the shops make it out to be
Old 11/28/12, 11:01 AM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Time to hit the next level!
Old 12/20/12, 12:18 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Best way to link any rig!
Old 01/04/13, 12:08 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Ready for any task you can put it up against!
Old 01/07/13, 08:15 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Hope everyone had a great weekend!
Old 01/16/13, 03:42 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Always a favorite!
Old 01/17/13, 12:38 AM   #10
broncoitis
broncoitis's Avatar
R.I.P Roscoe and Daisy! Miss you so much!!!
North Jersey
What is the issue with a 4 Link on the street? Or is it a bunch of crap? Seems that the ride would be better and that a Sway Bar would be a definite plus. Anything to add. Always lookin for more things to do to!
Gonna subscribe to this for the future!
Rob 1970 Bronco: Rebuilt 302, EFI, Exp Serp, Vintage Air, Cust Console, Corbeau Seats, etc...
Build: Springtime or Bust!!!
broncoitis is offline   Reply With Quote
Old 01/21/13, 11:16 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
If installed correctly, I see nothing wrong with a 4 link on the street. Plenty of customers do it with no issues.
Of course you can't beat on something and expect it not to need adjustments every so often if your hard on your rig.
Old 02/08/13, 01:08 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Thank you for all of the orders guys!
Old 02/24/13, 06:35 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Ready for more flex? The 4 link is the way to go!
Old 03/05/13, 11:34 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
All in one kit at a price you can afford!
Old 04/08/13, 10:47 AM   #15
Gravel Maker
Quick with a Laser!
Sacramento
A 4 link is better than a no link!
Page generated in 0.36897 seconds with 59 queries
