Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 02/16/15, 12:21 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Tube Shock Towers!
Here is a pair of 1.5"x.120 wall DOM shock hoops. These are not the typical both sides even type everyone else makes because often your mounting surface and where you need to mount them simply have to be different. These make it easy to mount them tilted forward or rearward and have enough tube. If you are one of the lucky few that can mount them straight up and down just cut off the extra tube!
They come with two pair of our curved shock tabs so you can fine tune the height adjustment by the position of the tabs.
Shock Hoop 1.5" - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 01/27/16, 11:54 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
Easy to use and easy to buy
Old 03/15/16, 11:23 AM   #3
Gravel Maker
Quick with a Laser!
Sacramento
Tall enough to pack a tall shock, coil-over, or airshock under the hood, but easily trim-able to any height to fit your rig.
Old 03/29/16, 11:56 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
These keep a guy busy on the tube bender all day!
Old 04/13/16, 06:33 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
There are no questions with these, they do a simple job, and are a straight forward design.
Old 04/26/16, 06:53 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
1.5" x .120" Wall DOM is some strong s**t for how light weight it really is.
Old 05/29/16, 04:39 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Get it done with a professional finish!
Old 07/13/16, 05:36 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Not too Heavy, but plenty Heavy-Duty for whatever you can throw at it!
Old 09/13/16, 05:04 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Weld it right to the frame, do a little gusseting and call it a day!
Old 10/01/16, 11:47 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Wonderfully simple.
Old 10/25/16, 10:28 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Get a pair installed on your next project, or the current one!
Old 11/19/16, 10:26 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Shocking!
Old 12/26/16, 06:14 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Here is a great way to get your shocks or coil-overs done in no time!
Old 01/06/17, 12:08 PM   #14
cody72sport
cody72sport's Avatar
Las Cruces NM
any pictures of this installed?
cody72sport is offline   Reply With Quote
Old 01/07/17, 10:55 AM   #15
Gravel Maker
Quick with a Laser!
Sacramento
For some reason the image I am trying to link to won't post here, but follow the link below, toward the end of page 1 is an installed set of our hoops, and a little discussion on mounting methods is in there as well.
https://ck5.com/forums/threads/tube-...towers.319868/
Page generated in 0.42429 seconds with 59 queries
