Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 04/06/17, 10:20 AM   #1
Bronc0311
Newbie
Austin
Tv cable
I'm running a 5.0 Efi with aod. Installed winters shifter and trans started acting up. Won't shift properly and requires a high rpm to engage into 1st gear, runs through gears quickly and shifts hard. Tv cable had some janky fab done to the adjustment block on the cable so I pulled a used one from a junkyard. Still shifting hard and still requiring high rpm. Tried all the adjustment info I found on YouTube and mustang forums with no success in fixing my problem. Is there something I'm missing, are these cables notoriously diff to adjust or is a new one my best bet? Any suggestions would be greatly appreciated
Bronc0311 is offline   Reply With Quote
Old 04/15/17, 10:56 AM   #2
lbrendis
Newbie
so cal
Might want to move this post over to the tech forum!
72 with 302, AOD, disc/drum, hydraboost, 3.5 SL Larsbars,1" BL,35s KM2s,bilsteins w/F250 towers,4:56's 31 spline w/Yukons,
lbrendis is offline   Reply With Quote
Old 04/15/17, 11:51 AM   #3
wepuckett
Morganton, NC
eBay: wepuckett
Lokar sells all the parts for that if you call them and tell them what is going on they will be very helpfull and give you all the part numbers so You can price out the best place to buy the parts.
wepuckett is offline   Reply With Quote
Old 04/15/17, 11:55 AM   #4
needabronco
needabronco's Avatar
Prescott/Farmington
Id say your tv cable is binding or improperly adjusted. You need to set the tv cable by line pressure, you can jerry fab a cheap guage to do this. I run an Art Carr shifter and an AOD and Im usin BC Broncos tv and throttle cable.
When you installed your shift linkage your tv adjustments were changed.
1971 Mall Crawler- Resto mod. http://classicbroncos.com/forums/sho...dabronco+frame
1970 Basket case
1966 U14
needabronco is offline   Reply With Quote
Page generated in 0.31409 seconds with 55 queries
