Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 04/21/17, 06:16 AM   #16
Cooper
Cooper's Avatar
Press on... Phil 3:14
Northeast
Could you post a picture of the backside of both lights.
I've got modifications behind the grill and am trying to assess fitting and maybe cutting or modding some more.
1974 - a work in very slow progress
"In a Bronco the other vehicle is your crumple zone."
Cooper is offline   Reply With Quote
Old 04/21/17, 07:01 AM   #17
Heus33
Heus33's Avatar
You down with HID? Yeah you know me!
Buffalo, NY
If your stock sealed beams fit, these will fit. I can snap pics if you'd like.
Heus33 is offline   Reply With Quote
Old 04/21/17, 03:26 PM   #18
gr8scott
gr8scott's Avatar
Great Scott!!
Maui, HI
Here's the 13s
Click image for larger version
ID:	418523   Click image for larger version
'74 U152 | 302 | C4 | D20 Twin Sticks | PS | Front discs + Hydro | MSD 8352/6A | Centech Wiring | 3G 130A | Detroit Lockers
Summit M08600VS | TFS Twisted Wedge |3.5" SL | 31x10.5x15 Dick Cepek MT's | US Wheel Indy Slots
gr8scott is offline   Reply With Quote
Old 04/22/17, 12:53 AM   #19
Godwick
Godwick's Avatar
Santa Barbara, CA
Any problems with condensation in the lenses?
http://sbwebdesign.info
351w roller block; 4.11 gears; nv3550; edelbrock 650 4-barrel; performer intake; msd distributor; 1" body lift; 1" leveling coils in front; dana 44 and ford 9"
Godwick is offline   Reply With Quote
Old 04/22/17, 03:12 AM   #20
Heus33
Heus33's Avatar
Buffalo, NY
No, these come fully sealed.
Old 04/25/17, 03:19 PM   #21
Heus33
Heus33's Avatar
Buffalo, NY
I still have a bunch of Pro7s left if anyone is interested. The Lucky13s are almost gone.
Old 05/05/17, 03:26 PM   #22
Godwick
Godwick's Avatar
Santa Barbara, CA
Last Question, Heus:
How bright are the lucky 13s compared to KC highlights? I see the lumen output, but what about lux down the road?
Thanks,
Old 05/06/17, 09:15 AM   #23
Heus33
Heus33's Avatar
Buffalo, NY
Thanks,
Sorry but I haven't compared them to the KC Highlights. If its their typical reflector based LED setup I would say that this should be comparable. Hope that helps!
Old 05/06/17, 11:30 AM   #24
BigToe
BigToe's Avatar
Tucson, Arizona
As far as the depth of these lights, do they stick out further than the stock headlights?
Be somebody...drive a Bronco.
BigToe is offline   Reply With Quote
Old 05/06/17, 11:41 AM   #25
BigToe
BigToe's Avatar
Tucson, Arizona
Do these lights physically stick out any further than the stock headlights do?
Sorry for the double post, didn't think the first one went through.
Old 05/07/17, 03:24 AM   #26
Heus33
Heus33's Avatar
Buffalo, NY
No worries! No, they don't stick our further than stock lights and the depth is about the same (probably a bit shallower too) so no fitment issues here.
Old 05/12/17, 07:21 AM   #27
Godwick
Godwick's Avatar
Santa Barbara, CA
Just got my pair of Lucky 13s in the mail the other day. Can't wait to put them on the bronco and will post pics when I do! Quick question, Heuss: is there an instruction sheet for wiring in the DRLs or blinker?
Old 05/12/17, 12:23 PM   #28
Heus33
Heus33's Avatar
Buffalo, NY
Sorry about that - you were supposed to have received instructions with the lights, my apologies. Here's the info:
Your new Lucky13 headlights can be installed to operate the low and high beam lights with no modification to your existing wiring. Simply plug the stock headlight plug into the green plug on the back of the Lucky13 headlight and you are all set! If you wish to use the Daytime Running Light (DRL) and/or the turn signal features please follow these steps:
DRL
The DRL is controlled via the red wire coming out of the back of the headlight. To operate the DRL, this red wire can be connected to any 12V source (usually hot when your ignition is on) or a separate switched power source.
Turn Signal
The turn signal function is controlled via the yellow wire coming out of the back of the headlight. To operate this function, the yellow wire should be connected/tapped into your turn signal circuit (you’ll need to locate which wire is hot when your turn signal is activated). If connected, the top and bottom LEDs will automatically switch on and start blinking amber when your turn signal is activated.
*Questions or support, please email support@HIDprojectors.com or call 716.662.3479. option 2, M-F 9a-5p ET
Old 05/13/17, 12:43 PM   #29
Godwick
Godwick's Avatar
Santa Barbara, CA
Just installed mine right now. Definitely going to paint the buckets black to match, but just wanted to get them in to check them out. Easiest install ever! Literally 6 screws. Also going to wire in DRLS and turn signals when I clean up the buckets. Will post some night before and afters later when it gets dark.
Old 05/14/17, 02:56 AM   #30
Heus33
Heus33's Avatar
Buffalo, NY
That's awesome! I'll share these pics on our IG page too - its @hidprojectors
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.41711 seconds with 55 queries
