Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 05/18/17, 12:38 AM   #1
JB Fab
JB Fab's Avatar
The doctor said "if it hurts, don't do it"
Salem, Oregon
Shift-rail kit Early Bronco D-20
Due to the requests for shift-rail kits for the Early Bronco D-20s we are pleased to be able to offer.
Replacement shift-rails for Ford's version of the D-20 transfer case (Bronco 66-77).
Improved profile to reduce the possibility of "popping out" of gear, and increase firmness of shifting. adjustable detent kit included to allow adjustable shift firmness
These stainless steel CNC machined shift-rails replace the stock shift-rails in the 66 to 72-1/2 ("T" type) or the 72 -1/2 to 77 ("J" type).
If used to replace the shift-rails in a "J" type case, you will need to use a "T" type shifter.
These shift-rails are not compatible with stock shifters, they are designed for twin-stick shifters. This shift-rail kit allows the use of front wheel drive high and low, without the possibility of cross-shifting (high / low combination) when installed according to the instructions.
To install on a "T" type case you will need the two stock internal interlock pills
To install on a "J" type case you will need one additional interlock pill
NOTE: replacement of the shift-rails in a D-20 requires a complete tear-down of the transfer case, and is typically done during a rebuild
Kit includes, New stainless steel shift-rails, external interlock devise, adjustable detent kit
Made in USA
$95
Click image for larger version
Name:	JB Custom Fabrication D20 shif rails.jpg
JB CUSTOM FABRICATION LLC
www.jbfab.net
JB Fab is offline   Reply With Quote
Old 05/18/17, 12:42 AM   #2
JB Fab
JB Fab's Avatar
Salem, Oregon
Use promo code EB20SR15 for
$15 off until July 1st 2017
www.jbfab.net
Old 05/30/17, 01:22 PM   #3
gobeavs
Klamath Falls, OR
Got a set of these! Easy install and works like a champ! Now to get the whole thing back in the rig so I can actually play with it. Thanks guys!
gobeavs is offline   Reply With Quote
Old 06/03/17, 06:05 AM   #4
Nevadasmith
Fallon, Nv
My old shift rails were toast had rust and horrible grooves from the detent balls, I got a set, and the twin stick kit. Exceedingly happy with the quality, instructions were good. I could not be happier with the finished product! Thank you!
Nevadasmith is offline   Reply With Quote
Old 06/04/17, 07:50 PM   #5
JB Fab
JB Fab's Avatar
Salem, Oregon
Thanks for the feedback, and the orders!
Cheers,
Jon
www.jbfab.net
Old 06/26/17, 09:32 AM   #6
JB Fab
JB Fab's Avatar
Salem, Oregon
Thank you for all the orders!
Promo code for $15 off, is good until Friday the 30th
www.jbfab.net
Old 07/16/17, 11:38 PM   #7
sykanr0ng
sykanr0ng's Avatar
"You say overkill like it's a bad thing"
Greeley, CO
Do you know of a source for the interlock pills?
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation or authenticity...My Dad called that sick and wrong
www.coloradoclassicbroncos.com
sykanr0ng is online now   Reply With Quote
Old 07/18/17, 07:03 AM   #8
JB Fab
JB Fab's Avatar
Salem, Oregon
We just got 500 of them from heat-treat last week $7 each, they will on our website by the end of next week.
I you need one, (or two), just send me an email and I will get you taken care of.
Jon
www.jbfab.net
Page generated in 0.33502 seconds with 62 queries
