    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
AL 1971
Status
Not open for further replies.
6677ebman
Solid mostly original '71 U15, 351C, power disk, PS, PTO, 99% rust free, one repaint (Boxwood Green), runs/ drives great. Text @ 205-468-7670 for pics
JGbronc
Bronco Maniac
I've seen this Bronco in person. Very solid Bronco and well priced!
Good luck on the sale, Scott!
surfer-b
that want last long, I cant believe it hasn't already sold
Jaxgtc
Something about a whip antenna and a gun rack that just make a Bronco. Check that.... 2 gun racks!!!
01JLH
Guys, I went and took a look at this bronco. It is a good honest bronco. solid under the hood at the firewall where the inner fenders usually rust. Only problem area I could note is the drivers door. It has several extra screw holes from mirrors over the years and across the door skin about an inch or so from the bottom there is a streak of rust. Probably would be best to replace the door skin. It has a floor shifter for the 3 speed manual transmission that shifts good even though I was not used to it. The belts will squeal if you race the motor a little. The motor could probably use a good tune up, but the 351 Cleveland installation was pretty well sorted out. floor pans looked really good, I don't think any replacement is needed anywhere there. All exterior panels look good with the exception of the drivers door issues. The seller sent me plenty of pictures before I went over to look and the pictures represented exactly what I saw. This bronco has been driven and used but is not the worse for it. It has really good bones to drive as is with a little maintenance or to restore. the seller is a stand up guy and you won't go wrong if this is what you want. I am not warrantying this bronco by any means, but it is a good honest bronco.
Jaxgtc
Good info. What is your assessment of the rust on the roof. Did you see anything in the inside rear corners of the roof?
01JLH
Looked like surface rust on that. I did not dig into the corners and it had a full head liner in it. Headliner will need to be replaced as it is warped up like humidity has got to it over the years.
rguest3
She arrived at about 8:30 tonight. Thanks Scott
Franco - Its a U15GLJ9XXXX - August 1970
rguest3
1strodeo - I already have a Thread started on it. Chat section. pictures included.
Status
