Fuel Injection upgrade: How tough is it?
chirolaker
Kalispell, MT
Hey guys. I'm really interested in upgrading my 351W to fuel injection. What are your opinions and experiences with the different brands, and how hard is it to do myself. My self-taught mechanical skills are lacking and this seems like it would be quite involved.
tpep3
Elmhurst, IL
I just did the Holley Sniper. I have no car background and I thought it was borderline easy. A lot of great instructional videos online.
sanndmann3
I did the E.D.I.S. route with EFIGuy doing the harness and computer. Finding a Lightning upper and lower was the hardest part. It is absolutely doable, not that difficult.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I'm planning to go with the Holley Sniper. Seems super easy. Gets away from carb issues. Plus it will keep my engine bay neat and clean the way I want it to look.
RADO
Phoenix
The most work intensive part of adding fuel injection for me was converting to a high pressure fuel pump, new fuel tank and running all brand new fuel lines. Not hard, but time consuming. The fitech install was quick & easy, with most of the effort in the tuning after turning the key.
Timmy390
Conway, AR
Don't you mean paying for the Lightning upper and lower is the hard part? LOL Jaw dropping prices is all I've seen
Explorer upper fit the Lightning lower. There is a marine version of the Lightning lower (it's cast iron) and can be had for less. I run this combo.....
You don't NEED a new EFI tank. I'm running the stock tank with external E2000 pump. Works great on my rig but I don't offroad....Might have some issues there I don't know. I run the return into the vent hose.
Tim
gnpenning
Bronco Slave
The after market systems should be easier and cheaper for the initial install. Factory systems will be easier to find parts and support down the road.
You are local to me. Pm me if you like, I'm always happy to meet Bronco owners.
KyleQ
Easiest?
Fi-Tech or Sniper - 7 wires, an inline fuel pump and a return line run to either the filler neck or a tank vent. No need for a new tank.
Best Experience overall?
Ford EFI
Easiest Ford EFI?
I'm going to go with Mustang on this one, the entire setup is stand alone and will drop on and run with zero modifications beyond the intake manifold and distributor. A tune is highly recommended - EFI Guy will be your resource for all Ford EFI swaps.
Most feature filled?
Hands down Explorer EFI. It seems to be the popular thing now, OBDII, trans control, EDIS ignition.
The obvious pro vs con is that the Fi-Tech or Sniper systems require the least work and RETAIN that original carb look. The Ford EFI have that large plenum intake style that makes them often difficult to fit under a hood.
I've run the 2bbl and 4bbl carb on a 302, swapped to speed density Ford EFI on a 5.0, then went 351W with Mustang EFI. After that ran well I had EFI Guy tune it and it ran the best out of any combos. I recement built a really aggressive motor for my trail truck and went Fi-Tech on that - runs 95% as good as the Ford EFI did. Zero regrets.
rguest3
Well said KyleQ.
Stock 5.0, I'd go with the Ford EFI. The Ford system can handle some modifications to the motor but there is a small window. EFI guy can help.
The new Speed Density systems (FiTech, Sniper, FAST) are not the same as old. They can perform Very well and "Learn" to run correctly with modifications and Cam choice. They can handle a more built motor with many modifications.
1strodeo
Squirrel Watcher
Wisconsin
My local yard has a Lincoln Town Car 86-87? with this setup...IF I were to go EFI could I use this setup? What would I need to grab? thanks -Jeff
RADO
Phoenix
Tim
True, I didn't say you need a new tank for EFI. It's one of those, "might as well upgrade the tank while I'm at it" scenarios. ;D
KyleQ
It's the lowest HP EFI setup available - I would skip it.
Timmy390
Conway, AR
Oh I get it......when in Rome......:cool: but the price tag was a bit much for me at the time of my conversion. Was trying to do mine on the cheap. I took on engine and Ford EFI all in one swing. It got to be a bit $$$ in the end but could have been much worse. Then I had my head issues with the new build and it got much worse. I DO plan on a new tank at some point but it runs so well using the old tank, it's hard to spend the $$ to upgrade at this point.
Tim
Timmy390
Conway, AR
Non HO and the EFI is Speed Density not Mass Air.
It will run and some will say it runs well however it doesn't have much support because it's SD and not MA and will not respond to upgrades well. BUT it will work.
Now you could get the ECM pinout and modify the wiring harness to a MA stang ECM pinout (I did this with my donor van) adding the MA sensors and such.
It's a project......
Tim
NYLES
Tim
I make you a deal on one!!!! Lighting
C
chirolaker
Kalispell, MT
Thanks so much for all the great info! I've been out of town and away from my computer so I haven't had the chance to reply. I really appreciate all the support advice. gnpenning I'll probably be getting in touch with you at some point. I just had the suspension and exhaust done and will be having the body work done soon. If you seen an ugly brown '77 running around town with the rear lift gate bunjeed because of all the parts in the back, that's me.
Timmy390
Conway, AR
It's all about the funds....and I'm bone dry after popping for new rims and tires. Oh and the Samurai x2 deal I fell into.
Eating ramen noodles for a while here on the old homestead.
But you know I'll keep it on my mind......;D
Tim
