How to remove shift linkage arm
76YETI
KC METRO
Ok, so I usually break stuff, so I thought I would ask the question....I have removed the lower portion of the transmission selector rod from the side of my c4 transmission....how to u remove the top portion? Looks like it is pressed in?
Viperwolf1
electron whisperer
It's lightly pressed into a plastic bushing. The plastic will usually break if you try to remove it but new ones are available.
sanndmann3
Lightly pressed? Mine was really tight... I put some eat on it and it came out much easier. Replaced it with a new one ...
jmhend
it is a pain to remove but finally got mine removed today with a C-clamp to push the back of the rod through the hole.
76YETI
76YETI
KC METRO
Just wait until you have to reinstall it.....If you replace the plastic bushing it is a pain in the butt. I finally heated the rod up and it slid right in. Kinda sounds like a porno :cool: ....just like Sanndmann
LUBr LuvR
Had to replace one last weekend. Used some soapy water and a visegrip that had been modified for another purpose, but worked fine for this.
micked
Hell, u should patent that tool
Can someone post a pic of this upper bushing with the shift rod
Not sure if mine is right ... doesn’t seem like it
Viperwolf1
electron whisperer
It's not in yet. You need to press the bushing in the arm first, then push the rod in the bushing.
micked
Yea I did it backwards thanks guys!!! Seems like it should have been easier!! Got it and appreciate it!
