Its My Official Build Thread (new pic 06 nov2014)
F
fordguy
here are the pics of ecoat on the tub
she is finally back home fresh from ecoat
jon-r227
Nice build so far! Body looks sweet in e-coat. Hopefully I'll be there in a few weeks (just started my build last week and have already stripped it and replaced floor pans, inner rockers, kick's and inner fenders). Responding to your post in the other guy's thread about door posts. I have read a couple places that the driver's side has to be trimmed. My passenger side went in perfect and hardly had to move the post when I put the door in, but the passenger side is a train wreck. The inner fender doesn't line up with the kick panel extension and the flange on the front side of the kick panel is not vertical (bottom is kicked out toward the rear, so its angled forward). What kind of trimming and beating did you need to do to get yours squared up?
Also, might have missed it but can you recap your costs, sources, and turn-around times for acid dip and e-coat?
F
fordguy
jon, i was just saying as a general rule you have to beat bang massage. just like with my floorpans, after i put them in had a gap. body hammer massage those gaps. my cost basically ended up being about 2 grand for strip and ecoat. both processes were slow, they have a lot of work. one thing i did that cost me a few bucks was brought the truck back home after the first strip. if i would have taken my floorpans over and got them dipped i would have saved a couple hundred, but instead he had to re-dip. if i had it to do over i would just do all the metal work send it over for strip and ecoat. got my dip and ecoat out of metal finishing services in jackson, ms.
F
fordguy
trans is built and have started on the transfer case.
F
fordguy
Pooh, i am using the 4R70W with baumanator controller for now. i like the explorer wiring harness setup on here that is being discussed
F
fordguy
working on getting the body back on frame so we can do body work. looks like this is gonna be a 10 year build lol.
englewoodcowboy
Lick Creek Restorations
What is the purpose of the ecoat? I first assumed it would be applied like a plating getting everywhere which would be wonderful for cavities etc. however it looks like the sprayed it on so it only is applied where you see it. If that is the case, a good 2K epoxy would be just as good if not better perhaps? Please correct me if I am wrong, just trying to make sense of what I am seeing.
croft75
me to , far as I know coat is a dipping process , I wonder if it was powder coated
F
fordguy
it has been dipped not sprayed as in new car e-coat process. a contract company who does work for Nissan dipped it, that includes the frame too.
F
fordguy
got the body back on the frame last night.
F
fordguy
thanks. took the doors and grill today to get them stripped. feels good to be headed north again on the build. I am working mechanical stuff while I wait on the doors. we will get the doors and fenders fitted before starting body work. I have most of the mechanical stuff like engine, trans, tcase. wiring harnesses (efi and body)
Crawdad
Bringing this ecoat build back to the top! Any updates or are you still thawing out?
F
fordguy
no i am regrouping and freshening up the engine. will pull the body back off and run all lines and re-install body. ran into some issues on the engine build so it gonna take a little longer. decided it would be easier to run all the lines with the body off.
Crawdad
I'm looking at possibly e-coating my tub when the time comes. It's becoming a bear finding a company will to do it that's not contracted out by BMW, Toyota, Ford, GM, blah blah blah. I'm in SC and I'm having to resort to GA, next will look into NC.
