Go Back   ClassicBroncos.com Forums > Classifieds > For Sale - 66-77 Broncos by members only
Closed Thread
Old 05/16/18, 05:13 PM   #1
CartF1Fan
CartF1Fan's Avatar
Essentially bought a title
Cary
77 Project
City: Cary
Price: 18,000 or best
Gauging interest to sell my project. 1977 Project Bronco that has been meant to be a ground up stock resto. Has good IL title in my name. Have a Marti Report for it. Looking for someone interested in the whole kit. I'm NOT parting things out. If interested, email me with your best offer j31m@juno.com
As it sits now it is a frame, suspension, engine and transmission. Frame and axle housings have been cleaned and repainted with POR 15. Rear axle has new Limited slip differential (3.5:1) and new axle shafts. New spring and shocks. Rebuilt rear drums. Front end has stock differential and all new parts otherwise (shocks, bushing etc). New front disk brake parts as well.
Have new steel body parts kit from Bronco Graveyard. Centech wiring harness. Was going to have C4 auto and Dana 20 rebuilt but have not to this point. Have rebuilt 302 ready to go in with stock exhaust manifolds. Old 302 (.060 over) is still on it. Have an extra set of 302 heads as well. It currently has a carb on it but I have an EFI fuel tank/pump (not the 23 gal one), and fuel lines as I was going to set it up as EFI.
Truck has 70s style slotted aluminum rims and decent tires (one has a slow leak). Finally, it comes with a steel hard top that does need a bit of work but should be savable. Have a total of about $18000 in it right now. That is all in parts, not labor. Everything has been new to this point. If I can get a fair price out of it I'll let it go as we are in the midst of a move. If not, I'll finish it up in the new place. I could possibly help with transportation to a certain degree, but cannot ship.
Post any questions so I can answer to everyone. If interested, email me with your best offer j31m@juno.com
Pics at https://drive.google.com/drive/folde...UU?usp=sharing
CartF1Fan is offline
Old 05/28/18, 08:39 AM   #2
CartF1Fan
CartF1Fan's Avatar
Cary
Someone asked for a parts list so I'm posing the list below.
ITEM# DESCRIPTION QTY TOTAL
Bronco Graveyard
14180 66-77 Ford Bronco Unassembled Body Tub Kit 1
18060 1966-1977 Ford Bronco Centech Wiring Kit Complete re-wire kit 1
14054C 1968-1977 Complete Left Door Shell 1
14010P 66-77 Bronco Custom Plain Steel Hood (truck freight only) 1
14001 69-77 Bronco OEM Grill Shell 1
14011 66-77 Bronco Fender Pair with OEM Style Stamping new 1
14141 1966-1977 Ford Bronco Windshield Frame, Steel OEM Style New Steel 1
14145 Windshield frame hinge stainless steel Stainless steel new 1
14130 1966-1977 Ford Bronco OEM Steel Tailgate OEM 1
18032 Neutral Safety Switch 73-77 1973 - 77 1
11611 Gasket & Seal Kit, Dana-20 new 1
11572 Lower J-Shifter Boot, 1973-77 New 1
13099 1966-1977 Ford Bronco Body Mounting Hardware 1
12172 D44 Heavy Duty Inner axle, left 1966-77 Uses 760X U-joint 1
12173 D44 Heavy Duty Inner Axle, Right 1971-77 Uses 760X U-jo Uses 760X U- 1
13080 Bump Stops, Front 2 Black-Pair Pair 1
12114G D44 Front Cover Gasket, Dana 44 1966 - 77 New 1
12199 D44 Inner Axle Tube Seal, Each Each 2
12218 D44 Spindle 1976 - 77 w/Disc Brakes new 2
12232U Dana 44 Hub and Rotor, Disc 1976 - 77 Unassmebled 2
12232K Hub & Rotor Bearing Install Kit, TIMKEN BEARINGS 2
12178 D44 Outer Axle, Uses 760X U-Joint 1971-79, uses 760X U-joint 2
12195 D44 Dana Spicer Heavy Duty U-joint new 2
12198 OE Spicer D44 Outer axle slinger, 1973-77 new 2
12221 Dana Spicer OEM Spindle Bearing Repair Kit 1973-77 new 2
12204A Dana 44 Ball joints, pair new Aftermarket 2
12580 Front Caliper, Right 1976 - 77 1976 - 77 1
12581 Front Caliper, Left 1976 - 77 1976 - 77 1
12549 Caliper Hose Copper Crush Washers Pair 2
13756 Stock Suspension System 1976-77 Black Bushings, w/Shocks 1
12698 1976-1977 Ford Bronco Rear Drum Brake Rebuild Kit, Large Bearing Axl 1
Toms Bronco Parts
Track Lock w/31 Spline Rear Axles - Select Size/Year
Leaf Spring Shackle, 66-77 Ford Bronco, New (each)
CJ Pony Parts
FT1013OE 1976-77 BRONCO OE STEEL COMPLETE BRAKE LINE KIT FOR POWER DISC BRAKES
BMB1 66-77 BRONCO BODY MOUNT BUSHING SET - OEM RUBBER
BKAM149 1966-1970 BRONCO BODY & INTERIOR ASSEMBLY MANUAL
Amazon
Primecooling 3 Row Core Aluminum Radiator +Fan (16 Inches Dia.) Kits for Ford Bronco 5.0L V8 Engine 1966-77
TanksInc.com
1- USPT-GH - Universal Fuel Tank with 2" OD Neck & Connecting Hose
1- GPA-2 - Deluxe Fuel Pump Module - 190 Liters Per Hour - Up to 450 hp- kt
1- TAN-ORG - Fuel Tank Sending Unit Early Ford & Mopar Type 5 Hole Design - 73-10 Ohms
Old 06/03/18, 06:43 AM   #3
CartF1Fan
CartF1Fan's Avatar
Cary
So if this going to go it needs to be gone by June 19. I would accept $14000 cash for it.
Closed Thread
Page generated in 0.28126 seconds with 63 queries
