Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/23/16, 04:45 PM   #16
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
mini73-
I will see if I can find some installed pics for you, they are pretty easy to incorporate into an existing bumper most of the time. the round stock is 1.5" OD solid bar, that is what you would be welding to your existing bumper. Then the part that actually spins is 2-1/4" OD DOM that you can easily weld square or round tube to that would actually support the tire itself.
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 12/01/16, 06:00 PM   #17
Gravel Maker
Quick with a Laser!
Sacramento
Build it the way you want it!
Old 12/28/16, 02:54 PM   #18
Gravel Maker
Quick with a Laser!
Sacramento
Any way you want it... Thats the way you need it!
Old 01/30/17, 10:17 AM   #19
Gravel Maker
Quick with a Laser!
Sacramento
Round tube, square tube, plate, diamond plate.... Your call.
Old 03/31/17, 12:40 PM   #20
Gravel Maker
Quick with a Laser!
Sacramento
Dont quite like the look of anything on the market? Make it your self!
Old 01/02/18, 04:02 PM   #21
Gravel Maker
Quick with a Laser!
Sacramento
You CAN make it better!
Old 02/16/18, 01:12 PM   #22
Gravel Maker
Quick with a Laser!
Sacramento
Home-built is always cooler
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.29590 seconds with 62 queries
