Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 05/31/11, 07:34 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Thumbs up Panhard Kits from Ruffstuff!
These are pretty straightforward and simple, all it takes is a quick look and you understand what you need to do and more importantly, what you need to order!
We start you with 48" of 1.5" x .25" wall DOM tubing, then we make you choose between an axle Centered or Offset Bracket, and finally you decide if it will mount on the frame Inside or Outside. The Brackets give you 5 choices of mounting height.
It comes with a set of our 7/8" x 3/4" 4130 Heat & Cryo treated Heims with Stainless Misalignment and Hex Head weld bungs. The Hex Head bungs give you very fine adjustment easily. We also include the Grade 8 bolts in the correct length so you don't have to spend your day searching for them.
Here is a pic with both bracket choices so you get an idea of how it goes together...
http://www.ruffstuffspecialties.com/catalog/PANKIT.html
Dan Fredrickson 916.600.1945
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is online now   Reply With Quote
Old 06/14/11, 12:26 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
When its time you know where to find us!
Old 06/29/11, 12:46 AM   #3
strokers
Do you have a picture of this installed?
strokers is offline   Reply With Quote
Old 06/29/11, 11:55 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
I likely have some somewhere but every instal will be different...
Old 08/08/11, 02:25 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
When going full width you need to make a bunch of changes, this is one of them
Old 08/08/11, 05:14 PM   #6
mudstud
mudstud's Avatar
Excel, Al
I am going full width. I have an adjustable track bar now. Will the brackets you sell work with the stock style adjustable track bar. I would use heim’s and the DOM tubing but it will be driven on the street at a minimum of 50% of the time maybe more.
mudstud is offline   Reply With Quote
Old 08/09/11, 03:10 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
The bracket ID is set at a 2" width.
Old 08/31/11, 11:43 AM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Choices make it easy
Old 09/02/11, 01:03 AM   #9
1Ton73
1Ton73's Avatar
Roseburg, Oregon
Looks like a great kit!
1972 Bronco Sport/1995 Bronco XLT
1Ton73 is offline   Reply With Quote
Old 09/02/11, 10:44 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Thanks alot!
Old 10/03/11, 11:34 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
This will re-center your axle after a lift, without using something that bolts on and is going to bend or slip...Do it right the first time
Old 10/17/11, 12:58 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Extensions are always going to be a weak point and slip or break, avoid that issue by doing it the right way
Old 01/22/12, 11:31 AM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Time to move on up!
Old 01/22/12, 11:43 AM   #14
ilovemaui
ilovemaui's Avatar
2400 mi East of Paradise
Pacific Moist West
I think pictures of the products installed would be very helpful. How about a section on your website where you could display customer's rigs?
'74 LUBR, 408 EFI Stroker - Gone but not forgotten.
ilovemaui is offline   Reply With Quote
Old 01/23/12, 10:17 AM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Pretty good idea, I have tons of pics. Let me see about adding that section...
Page generated in 0.32871 seconds with 62 queries
