Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 12/15/11, 10:07 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Arrow D60 Full Float Rear Axle Flanges!
Something new for us at Ruffstuff! I tried to buy these from another vender but he wanted more than what I am willing to sell these for so we had to make them ourselves and improve them along the way
These are unique in that they will both work for Chevy or Ford D60 front spindles. These have both patterns. They are also made to clear the biggest of calipers.
So far we only make these with a 3.5" opening but the 3.25" are on the way!
The way we made them less expensive is all in the machinists' methods and these were made for us by Kyle at NWF. Kyle has a pretty good idea of the best ways to do things. The end result is what counts but the way you get there is what you end up paying for.
With these you can easily use a 35 spline shaft on the rear using common D60 front axle parts. I see these as a great way to use a 9", Sixty9, Solid14, or Torq rear third member and minimize your spare parts needs by using what you already use on the front axle.
These are made from 44W 1" Plate and machined for a press fit. They are $160 a pair for as long as we can afford it but we have 40 pair on the shelf as of today
http://www.ruffstuffspecialties.com/.../FLANGE60.html
Dan Fredrickson 916.600.1945
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 12/22/11, 02:49 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
These help you step it up to the next level for less
Old 12/23/11, 12:53 AM   #3
bludorbronc
central Iowa
are you going to make a set that slides into the axle bearing hole and bolts in so you dont have to cut the housing off. no welding, all bolt in to make a full floater.if so are you going to carry the caliper bracket for 15,5x5.5 and hub and rotor.
bludorbronc is offline   Reply With Quote
Old 12/24/11, 11:13 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
I don't plan to, it would add width (~3" overall) and that would also rely on multiple bolts rather than 1 good weld.
Old 01/03/12, 12:05 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Time to get your next project going!
Old 01/15/12, 05:13 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
We put another set on last night, this time I got some pics
Inside...
Outside...
And with the spindle and hub...
The truss is not welded for the last 3 inches so the brake brackets can be fitted up, Brian should have done them first but its going into his new car and you know how people want to see progress
Old 01/21/12, 02:45 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
These could also go on the rear of a 9", they can go on pretty much any axle!
Old 01/22/12, 10:14 PM   #8
78Scronco
78Scronco's Avatar
Illinois
making it a 9/60 rear?
78Scronco is offline   Reply With Quote
Old 01/23/12, 10:15 AM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Yes, thats the idea!
Old 02/14/12, 02:55 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Very easy conversion to Full Float!
Old 02/23/12, 11:17 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
This is one of the ways you can lose the snap ring issue 8.8's have and gain strength at the same time!
Old 03/23/12, 01:30 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Now available in 3.5", 3.25", & 3" ID so you can add them to just about any axle tube size...
Old 04/16/12, 11:25 AM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Time to make the switch?
Old 05/17/12, 11:40 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
A Full Floater is a stronger axle because it isn't pre-loaded...
Old 08/15/12, 05:45 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Thumbs up D60 Full Float Rear Axle Flanges!
The best way to up grade your rear end !!
Page generated in 0.33513 seconds with 61 queries
