Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 05/26/14, 10:27 PM   #31
SpareParts
SpareParts's Avatar
My wife understands my Addiction.
Gerald, Missouri
Here's a pic of my latest use of the bushings and DOM sleeves. Great parts that make life easy!
1972, EFI'ed 357W, C6, 1356 StrongBox/205, ARBed D60, Shaved 14 bolt, 4:10's, stretched custom 3 link front and rear, hydroboost, 4wheel disks, 40" Creepy Crawlers on DIU 17's & 39.5" TSL's on H1's, BUILT NOT BOUGHT -My Build Thread- -My Videos-
SpareParts is offline   Reply With Quote
Old 05/27/14, 04:37 PM   #32
mp
mp's Avatar
Austin, TX
Just ordered a set to run on my Ruff stuff 9" housing, but planned on using Ford spindles since I run a Ford D60 front end. I don't think here was any mention of the needed spacers on your website? Having been out for three years now, are the spacers part of the ring package (per your original post above)?
RLTW!!!
mp is online now   Reply With Quote
Old 05/29/14, 06:20 PM   #33
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
I just corrected the original post. I was half asleep writing it. What I had in my mind was the way the fronts went together but these are only for the rear. It was the spacing for the caliper bracket when working with front hubs, the Chevy bracket is within the stack and the Ford is on the outside. On the rear you would use a Weldon bracket and it wouldn't matter a bit.
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 06/11/14, 07:51 PM   #34
Joker11
Joker11's Avatar
Jeeps are like A-holes. Everybody has one!!
Yuma, Arizona
Why would one want to put Dana60 front spindles on the rear axle?
What am I missing?
Are you building 4 wheel steering setups?
Joker11 is offline   Reply With Quote
Old 06/12/14, 06:55 AM   #35
SpareParts
SpareParts's Avatar
Gerald, Missouri
To do a light weight rearend that has good clearance with 8 lug and full float. The 14 bolt, D60/70 and sterlings all hang down further and at substantially heavier.
Old 06/27/14, 09:33 PM   #36
Joker11
Joker11's Avatar
Yuma, Arizona
It sounds great except that I want all of that and keep my bronco 5 lug. Can we do that instead?
Old 06/28/14, 09:22 AM   #37
mp
mp's Avatar
Austin, TX
If you buy Blackbird's 5x5.5 spindle kit you can keep 5 lug. That is the direction I am going.
RLTW!!!
Old 08/22/14, 10:23 AM   #38
Gravel Maker
Quick with a Laser!
Sacramento
Friday is finally here, now lets get that rig and get it on the trail!
Old 08/22/14, 09:48 PM   #39
Joker11
Joker11's Avatar
Yuma, Arizona
Can you post a picture of all the parts laid out on a table showing all that is needed and how it goes together?
I am not grasping it in my head yet.
Old 08/25/14, 09:44 AM   #40
Gravel Maker
Quick with a Laser!
Sacramento
Give us a call, we'll see what we can do for ya...
Old 09/16/14, 10:11 AM   #41
Gravel Maker
Quick with a Laser!
Sacramento
A very popular setup!
Old 05/12/15, 09:50 AM   #42
Gravel Maker
Quick with a Laser!
Sacramento
Thanks for keeping us so busy these past few days!
Old 05/21/15, 09:41 PM   #43
Joker11
Joker11's Avatar
Yuma, Arizona
So can I get a high pinion front dana 60 and use these to make a high pinion rear?
I like the full floater and high pinion combo. If that is what these make possible.
Old 05/26/15, 03:02 PM   #44
Gravel Maker
Quick with a Laser!
Sacramento
You certainly could, although High pinion is weaker than low pinion in a rear application due to where the pinion is contacting the ring gear. But the Flanges can be welded onto just about any axle to allow it to support a bolt on front spindle for a full float situation.
Old 05/26/15, 03:04 PM   #45
Joker11
Joker11's Avatar
Yuma, Arizona
Its either this or a truehi9........
Page generated in 0.41841 seconds with 60 queries
