Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 06/20/13, 10:44 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Arrow All our Different Weld Washers!
When we first came out with our Weld Washers 8 years ago they had been made by 20 other companies for years. They were great as a preventative measure when first building a vehicle because they are 7/32" thick but were not as good for repair's. The reinforce a good hole with more than 3/16" of additional steel and come in 1/2", 9/16", 5/8", & 3/4" to cover the bases for you.
Then 3 years ago we added the Fixit Weld Washers. They were primarily for repairing a hole that was already bad from use. They create a clean new bolt hole in 1/2", 9/16", 5/8", or 3/4" and all are 3/8" thick so you don't have to worry about what you fix!
Now just 2 weeks ago we came up with something else along these lines that in some ways is even cooler! Our Threaded Weld Washers. These are used to add something to your chassis in as easy a way you can that is strong enough to stand up to years of use and abuse. They are available for a 5/16", 3/8", & 1/2" thread bolts and require a 3/4" hole to be drilled for mounting so they can be added for anything down to a 1 1/4" Tube and of course any plate or sheet stock.
I seriously see these as something that should be on pretty much any fabricators shelf because there are so many possible uses for them. I am not joking here, these simply make too much sense...
These are all found in our Reinforcements section where we have a whole bunch of things like these
Reinforcement Plates - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is online now   Reply With Quote
Old 06/21/13, 11:15 AM   #2
MarkH@Wildhorse
MarkH@Wildhorse's Avatar
Stockton, CA
I bought some of these a few days ago, I don't have a use for them right now either, but it's a cool enough product I wanted on the shelf for when I did need one.
E-mail - Mark@Wildhorses4x4.com
71' Bronco - Coilover's / 42 inch tires / other stuff I didn't need.
MarkH@Wildhorse is offline   Reply With Quote
Old 06/25/13, 07:40 AM   #3
TwoDalesDad
I can see a big need for these....someone was using their heads....great product...
TwoDalesDad is offline   Reply With Quote
Old 06/26/13, 11:08 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
We have already found some use for them here in the shop on the FJ45!
Old 09/19/13, 12:24 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Keep those orders coming!
Old 10/24/13, 12:35 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
We have sent out thousands of these so far!
Old 10/24/13, 01:48 PM   #7
orangecrush4u
orangecrush4u's Avatar
Shelter Island, NY
Those are wicked cool, I need some
72 74 79 93 so far
2008 sorta just a week early
2010 BYOB &Fall Cruise
2011 BYOB &Fall Cruise
2012 BYOB Break down
2012 MEB Gore meet broncoless though
2013 BYOB..Dave & Sean last show
http://top4x4sites.com/cgi-bin/arp/r...cgi?id=oldford[COLOR="Red"[/COLOR]
orangecrush4u is offline   Reply With Quote
Old 11/14/13, 12:11 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
The right way to fix it !!
Old 06/22/14, 12:11 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Keep a few extra in the shop, they come in handy!
Old 08/06/14, 07:06 PM   #10
Gravel Maker
Quick with a Laser!
Sacramento
There are too many ways to use these
Old 09/16/14, 10:10 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
These are so strong that we had to incorporate these into some of our products!
Old 06/24/15, 07:16 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Long overdue for a bump!
Old 01/23/16, 10:34 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
One of our coolest products!
Old 02/27/16, 11:02 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Time to get them on the shelf for your upcoming projects!
Old 03/02/16, 03:11 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Great repair items for wallowed-out bolt holes!
Page generated in 0.33177 seconds with 61 queries
