Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 01/29/15, 12:44 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Steering Stabilizer Brackets...
I am the guy that has always been of the opinion that you should never need these, however I just ran into a street rig that no matter what we did it still had wobble! Finally gave in and installed the stabilizer and no more wobble So we decided we should make a good one...
These are not for stock applications, these fit 1.5" or 1.25" tube. The are not made sloppy, they have an triangular hole so in one end (of the hole) they fit the 1.25" tube and the other end fits 1.5"...
Here you can see how they can fit either for a standard "shock type" stabilizer or a stud type...
And the flat type for clearance challenged rigs
Steering Stabilizer Plate 90 Degree - RuffStuff Specialties
Flat Mount Steering Stabilizer Bracket with Hardware - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 01/30/15, 08:31 AM   #2
Elite Broncos
Elite Broncos's Avatar
Looks great. How much are they?
Elite Broncos is offline   Reply With Quote
Old 01/30/15, 12:30 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
$25 before shipping and the 10% discount!
Old 02/25/15, 09:43 PM   #4
rubbman
rubbman's Avatar
catchy phrase goes here
Penntucky, CA 95946
What is the material used?
rubbman is offline   Reply With Quote
Old 02/26/15, 12:16 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Real steel 1020 plate, cold rolled...
Old 01/27/16, 11:54 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
I tried to find these without buying a complete kit and couldn't so we made them!
Old 03/15/16, 11:25 AM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Sized to fit our stout 1.5" OD tie rod, but available with smaller U-bolts if you still have a smaller stock size as well.
Old 03/30/16, 11:44 AM   #8
Gravel Maker
Quick with a Laser!
Sacramento
When you need one, you know it. Might as well get the best one out there!
Old 04/13/16, 06:35 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
2 Styles to fit any stabilizer need!
Old 05/04/16, 10:34 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
the 1/4" Plate really lets you get the U-Bolt nuts nice and tight!
Old 06/06/16, 09:00 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Some setups really benefit from a steering stabilizer.
Old 09/15/16, 06:00 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Calm your ti... I mean, steering linkages down!
Old 10/15/16, 08:28 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Control the shimmy...
Old 11/17/16, 10:25 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Does your steering suffer from some wander-lust? Chill it out with a steering shock!
Old 12/26/16, 06:12 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Simple pieces that make a world of difference!
Page generated in 0.33799 seconds with 61 queries
