New Name Build Thread: from "Obscure Machine" to "Bayou Hazard"
ObscureMachine
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
A. Got all the ujoints out of the rear driveshaft. I think they were original.
2. Painted the driveshaft to de-ButtStank it.
Q. Finally got one of the body lift mounts installed correctly.
&. Tapped the rear axle, carefully, reinstalled vent tube.
13. Wire brushed the rear driveshaft yoke
14. Removed the steampunk looking heater hose / temp sensor and installed proper ones.
€. Installed new fender bolts that weren't covered in paint and Denno-Liner.
D. Laid out all the parts for the serpentine conversion on a table
¥. Organized all my wiring, wire parts, connectors, heat shrink, etc. for re-wire.
3. Ordered all the switches (carling marine) switches for the new dash.
LL.Missed the local car show. 😢
sprdv1
REBEL
Must be nice to have the time to do that stuff.. Freaking always something here, honey do or someone around, something else needs done
Keep up the great work
ObscureMachine
ObscureMachine
World Headquarters
Ordered and received a bunch of parts. Still waiting for the Mustang to sell.
Messed with the driver door alignment and I think the backing plate is jacked up. (like, "messed" up)
Started poking around to get an idea what we might find when it goes to have the floor sandblasted. About what I expected. Bondo and fiberglass. I have no idea how far and wide it goes, but I anticipate a lot of new metal.
On the positive side:
  • Got all my switches in for the new dash. Blue LED carling style (even a big switch!)
  • 90degree water neck, radiator hoses and belt for the serpentine upgrade.
  • New plastic waterproof 6 relay box.
  • Custom wiper knob and bezel from Tom's.
  • A dewalt 18V 3/8 impact wrench (I have tons of 18v dewalt tools).
  • A pressure washer.
  • CV Collar will be here thursday so I can put the rear driveshaft back in and
    take it Saturday to get the pass floor pan put in.
Lots going on!
JGbronc
Bronco Maniac
Lots going on!
To help with the door alignment, Nick (delconick on here) sells shims that work great! I used one recently and it was just what I needed. They are on his site:
www.northeastclassicfordparts.com
ObscureMachine
ObscureMachine
World Headquarters
Drgreased and pressure washed underside of front half. Will need another round.
Removed stock lower steering shaft and installed WH collapsable one.
sprdv1
REBEL
You are one motivated individual man.. Keep it up
ObscureMachine
ObscureMachine
World Headquarters
Today I think I lost my best friend, also my mechanic friend who likes to help work on the bronco. I'm not sure we can be friends anymore. So, that sucks.
ObscureMachine
ObscureMachine
World Headquarters
IT'S A MIRACLE!!!!
The bronco sat and I didn't mess with it for years. But when I stopped working on it the blinkers (turn signals) had stopped working, and I spend a lot of time trying to track down the problem to no avail.
Today, suddenly, they started working!
Someone commented on a post that there is a metal screen on the rag joint that has something to do with grounding. I changed the lower steering shaft............. and now I have turn signals again!
ObscureMachine
ObscureMachine
World Headquarters
Lots of rot on the interior floor, and some on the wheel housing. I'm about to start some probing cuts to see what the floor supports are like.
half cab
Guru Bronco
You know what really makes you sick about these ole brutes is that ford did nothing really to protect them from rust.
sprdv1
REBEL
Keep it going there big guy... Be done in no time..
got a few things to take care of on mine after that wheeling trip
ObscureMachine
ObscureMachine
World Headquarters
Started cutting yesterday. Probably going to have to replace all of the floor some of the braces and at least two of the pillars.
ObscureMachine
ObscureMachine
World Headquarters
Ordered a welder today. Esab Mig / Tig / Stick.
Can also use it in my furniture making side business
