Bferrari
- Mar 6, 2013
- 856
Have you pulled your spark plugs to check them? Your plugs can tell you loads regarding what is happening in each cylinder. I would begin with the basics, look at the plugs, perhaps change the cap, rotor and wires. Failure of any of these items can produce issues. Are the plug wires burnt or grounding at all on the exhaust manifold? All things to check. Sounds like you have ruled out the fuel system so now you are on to spark and compression! I would definitely pull your plugs and look them over really good, make sure they are all similar in color. Let us know what how they look.
