Rear Sway bar bushings
Remos69
SW Florida
Could someone point me in the right direction to aquire the 1" rear sway bar bushings for a 1969 bronco (non 76/77). Cannot seem to find them at our sponsors or local parts store
sykanr0ng
I'm about 99 percent sure that a rear sway bar was not an OEM option on a 1969 Bronco, which means that you would need to find out who made it in order to find a replacement.
You are dealing with an aftermarket/retrofit part. Any of the aftermarket bushing companies (I use Daystar, local) will have a generic bushing. Usually with a new strap to match the outer shape of the bushing. And a few options for mounting holes.
Now if we are dealing with end link bushings, still the same process.
bronconut73
I was amazed at the selection of poly' Energy Suspension Bushings sitting right on the shelf at my local AutoZone
Remos69
Remos69
SW Florida
Thanks bronconut, went by AutoZone this morning and found both the hanger grommets and 1 1/8 bushings, O'Riley and advanced Auto did not have either as I had checked both last week.
bronconut73
Coolness!
Ain't it weird that AutoZone has all those poly bushings? I was surprised, lol.
