Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 05/19/07, 06:38 AM   #1
tdc_worm
Austin
full width axle swap advice...
I have a line on a D44/9" combo out of a 1978 Bronco. The front is open with 4.88 gears and factory disks. The rear has a Currie 9+ center section, 4.88 gears, a spool, and factory drums.
First question: is the 78 Bronco a good donor as opposed to other years?
Second question: what do you think is a fair price for such a set up?
I tried a search, but the misses is beating me up to get off the computer already!
tdc_worm is offline
Old 05/19/07, 07:31 AM   #2
Fishmanndotcom
Fishmanndotcom's Avatar
fastest bronco on jackstands
senoia, GA
yes 78 is a good year
i'd say $600-$700 would be a fair price. course for $1000 - $1200 you could get you a set of full width one tons!
-cutts-
72 Bronco-ish 302/NP435/D20/D60/10.25 5.88's welded F/R full hydro, hydroboost, taurus fan, 39"iroks, doved F/R, 39.5" iroks
Fishmanndotcom is offline
Old 05/20/07, 09:30 PM   #3
Apogee
Apogee's Avatar
Cuz that's how I roll.
Tangent, OR
Only drawback to the D44/9 axles out of the 78-79 big-broncos and F-trucks is that the front D44 have the cast wedges instead of welded variety. If you're going to wrist the housing, this is a good thing. If you want to link it or move in the C's to match the EB frame width, it's a lot easier IMO to find a 76-77 axle with discs and the welded C's.
Price will depend on condition and location. I bought a running 76 F150 4x4 for $600 off of Craig's list in order to steal the axles out from underneath it along with a few other parts. If the gears are the ratio you want, and you also want to run a spool, then they're worth more to you versus somebody who doesn't want those things.
Did you know that 95% of all statistics are made up on the spot?
Apogee is offline
Old 05/20/07, 09:40 PM   #4
Tito
CB Fire Starter
Tito's Avatar
The life of Tito is a path of mystery on the way to enlightenment.
Bakersfield, CA
A set of axles off a 78-79 Bronco up here in the NW go for ~ $400, $500 for the whole rig. I used a 78 (click the link in my signature of the big 12 inch for more details). I kept the wedges as they were as I didnt mind the width and I was going to use CAGE arms anyways, worked like a charm. I redrilled my coil cups in an inch and centered them to match the spring resting spot, I have a little bow but not much. I am very happy with my setup, only happier if they were 60's
Tito is offline
Thread Tools
Page generated in 0.31947 seconds with 56 queries
