I'm replacing my factory BB 9" housing with a new SpiderTrax housing. I had them weld on the ends as per EB BB 9" specs. I ran into a snag with the ends when I was putting everything together.
This is the factory housing/end with the axle shaft bearing race still in it, notice it's pretty much flush with the outer face of the end.
This is my new housing/end. Notice the bearing race is inset a good 5/8 of an inch or so.
This makes it so the spacer ring on the outside of the seal doesn't hold everything in tight when the retainer plate is bolted on. It also makes it so bolt heads of my lugs hit my brake caliper bracket.
What can I do about this. About the only thing I can think of is have some spacers machined to space that race out.... but then will my shafts not engage enough in the carrier?
Arrrggghh.
Edit: I just measured the old housing compared to the new housing. I did this before I had them build it, so I could give them a definite end to end measurement. The new housing is like 3/8" longer than the factory one, how they did that, I don't know. What that means to me though, I should be able to space those races out and be okay. There would only be ~3/16" less engagement each side in the carrier than the factory housing.
The ends are visibly different from the outside. The spidertrax one is obviously longer/deeper. Am I missing something obvious?
