Well my stuttering stalling problem has reared it's ugly head again. Couple of weeks ago, I would be driving the bronco when it would decide to stutter like it wasn't getting enough spark or gas? I figure it was the TFI and swapped it out for a used TFI I had and it has worked fine with maybe a minor stutter every once in a while (hardly perceptable) anyway, last night it decides it's really going to start acting up and so I bought a new TFI and installed it and hell it stutters right out of the driveway
Kinda interesting is that it never dies and if you leave it in second (manual tranny) and keep the revs up it wants to do it quite a bit and as soon as you shift into third it quits but starts up again when the RPMs start going up. I have a fuel pressure gauge and it reads normal 32psi when idling and if you blip the throttle it will jump up to 39-40psi. If I slowly rev the motor up the gauge stays down around 32psi which doesn't seem right?
I am kinda thinking that it's an electrical issue like maybe the Hall effect sensor in the dizzy? also is there a possibility that maybe the Accel E-coil is blowing up the TFI?
Heres the skinny on my rig:
newer 88 5.0HO MAF motor with explorer upper and lower
mustang fuel rail with stock mustang fuel regulator
stock mustang MAF
explorer 65mm TB
recently cleaned stock mustang injectors
explorer serpentine system with 4G alt
BCB intank EFI pump and tank
Ryans EFI harness
The dizzy has around 12K on it with a new (elcheapo) TFI
Accel E-coil
any and all suggestion appreciated.
Ben
