Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 08/05/07, 04:22 PM   #1
firehawk
firehawk's Avatar
Clawson, Michigan
My '71 Bronco Build
I am finally going to share the build of my '71 Bronco.
I bought it off Ebay last summer and had it shipped form Arizona to Michigan.
The previous owner had already put efi on it and hydroboost from a 94 mustang.
Pretty solid, at least from what I had seen here in Michigan. Of course after I bought it I came across several others that I probably would have bought instead. But that is hindsight. I still want to buy the one with a C4 and 351, slighty more solid than mine was and it has the prerunner front bumper I want.
Well back to the condition. The po also replaced the floor pans and it was not up my satisfaction as the welds were too small, 1/4 inch and 90% of them were not attached to the underlying structure, they just filled the hole he had drilled. I did like the extra thickness of the sheet metal he used over
stock but I decided to go ahead and buy the replacement floor pans from JBG. They fit pretty good and all I had to do was cut out the replacements and weld in the new ones along with drivers side kick panel.
firehawk is offline
Old 08/05/07, 04:33 PM   #2
firehawk
firehawk's Avatar
Clawson, Michigan
I have also covered the opening where the window goes after the po also cut out the widow frames. I like the half doors. The quarter needed to be straightened out and welded on the the front edge where it meets the drivers door.
Along with a few good size dents in the tail lamp corner, that is some thick metal on those corners and I couldnt get the studs to stick to it from my stud gun to pull out the dents. I had to weld a tab onto it and pull it out that way, and use alot of heat and hammer it out from the backside. A door pick also worked well.
The metal in the tub was in pretty good shape, I think anyhow. So far so good. I need to send it out to be stripped down, or start sandblasting it myself. I have already tigged up some of the few rust pinholes I found along with numerous holes from weatherstripping and god knows what else that was mounted in the tub.
I will not be running a hard top so I welded up the mounting holes in the top of the quarters.
firehawk is offline
Old 08/05/07, 04:40 PM   #3
firehawk
firehawk's Avatar
Clawson, Michigan
I am hoping I dont regret this, but I have welded in a piece of metal over the stake pocket holes in the top of the rear corners. I still need to weld in a couple pieces to patch the passengers side kick panel and apron, where they always rust under the fender.
I ended up picking up a different grille and drivers side fender because the ones that came with the truck were a bit trashed. I plan to put the '66 style turn signals in the grille.
I hope to be able to clear the intake with the hood after I install a 2 inch body lift.
More pics to come.
firehawk is offline
Old 08/05/07, 05:02 PM   #4
firehawk
firehawk's Avatar
Clawson, Michigan
I now need to make a list of things to do while I am gettin the body ready for paint.
Perunner front and rear bumpers w/spare carrier(might make my own version)
Crab cage or family cage
Rhino line tub
New seals for rear axle, transfer case and trans(might go auto)
Body lift
Swap d30 for d44
Winch
Serpentine belt setup
The list will grow as I think of it
firehawk is offline
Old 08/05/07, 06:07 PM   #5
Bitch'nBronco
Bitch'nBronco's Avatar
ZF Swap in progress
El Paso, TX
Sweet Bronco!
Bitch'nBronco is offline
Old 08/05/07, 06:53 PM   #6
Mtn Gote
Mtn Gote's Avatar
Pony Up!
Sultan Wa.
Awesome!
Cory,
1969 Halfcab Bronco w/ james duff 2.5" lift, 33" tires, 351 Windsor, stock 3-speed soon to be NP 435.
Mtn Gote is offline
Old 08/06/07, 03:44 AM   #7
Bronco Ben
Jckofalltrdes master/none
Bronco Ben's Avatar
found a second 1965 ford pickup
Coffeeville, Alabama
awsome! keep up the good work!
Ben
Bronco Ben
1965 Ford F100
1951 Ford F1
1968 Dodge Charger
1969 Dodge Charger (GL Clone)
Bronco Ben is offline
Old 08/06/07, 04:15 AM   #8
Chief Master Sergeant
Retired U.S. Air Force
Chief Master Sergeant's Avatar
The Green Machine
Spokane, Washington
That's a nice rig. You said that came from Arizona, but it has a lot of rust in it. Was it originally from AZ? Mine had the same inner fender rust yours had and the inner fender all but fell apart when I removed the front fenders. Ugh!
1972, 302, NP435, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, Hydroboost, WH 2 1/2" Suspension Lift
Chief Master Sergeant is offline
Old 08/06/07, 07:45 PM   #9
firehawk
firehawk's Avatar
Clawson, Michigan
I wouldnt say it has/had a lot of rust, but the floor pans, drivers side kick panel and the typical area where the fender aprons meets the kick panels. Also the bed floor had some pitting and a little bit of pin holes from rust. The pin holes and pitting I am tig welding up. The other panels are already replaced except for the pass side apron/kick panel patch I need to put in.
It might be alot of rust for a 71 from Arizona, I would not know. Maybe it came from somewhere else. It looks like it might have been a half cab, probably why the bed floor is a little rusty. Either way it is nothing I cant fix.
Just need to find the time and motivation.
I will try to get the updated pics tomorrow.
firehawk is offline
Old 12/24/07, 08:38 AM   #11
rmfreeze
rmfreeze's Avatar
You talkin' to me?
Benton, Arkansas
Looks like you found both! Keep up the work!
rmfreeze is offline
Old 12/24/07, 08:53 AM   #12
trlblazr
trlblazr's Avatar
The mystery man in the Desert
Mesa AZ
If it isnít the right year grille you can still go with the 66 style turn signals with a little mod work. Check out my photo gallery.
In Memory of Michael Stark, God bless
trlblazr is offline
Old 12/24/07, 02:44 PM   #13
firehawk
firehawk's Avatar
Clawson, Michigan
Exactly, I already picked up new ones from JBG and need to customize the grille a little.
firehawk is offline
Old 12/24/07, 06:48 PM   #14
Bitch'nBronco
ZF Swap in progress
El Paso, TX
lookin good
Old 12/24/07, 07:47 PM   #15
DonsBolt
DonsBolt's Avatar
Chestnut Hill, Mass
Looks like your doing awesome
Is it going to be black, or is that a primer??
1977 Bronco Ford Racing 5 Liter NV3550 456 Gears - 3.5 Suspension 35's
2011 RoushCharged Mustang GT 5.0 675RWHP 10.028@139mph
[COLOR="silver"]
DonsBolt is offline
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.32551 seconds with 55 queries
