Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 09/18/07, 01:56 PM   #1
Baja71
Baja71's Avatar
Dallas, Texas
Door alignment questions
Ok, prior to rebuilding hinges, I want to make sure everything is in align to see how bad the hinges really are. When I look at the reveal along the windshield to door frame, I notice that on both sides the gap closes at the top. The bottom is about 1/4"-3/8th, but at the top the windshield actually touches or almost touches the door window frame. The windshield gasket on the bottom looks OK (not squished too much). Should I align the windshield more vertical by sliding the hard top forward or does the windshield have only one position? How much leeway is there in sliding the hard top around in it's bolt holes?
thanks,
tw
1971Stroppe Baja
My build thread: http://classicbroncos.com/forums/sho...d.php?t=122019
Baja71 is offline
Old 09/18/07, 03:06 PM   #2
Mark in Memphis
Memphis, TN
I'm not a body man, but I would be more concerned about getting the gaps straight between the body and the door. Then move the hard top forward/back to get the windshield lined up with the door frame. On my Bronco there seems to be a lot of leeway in lining up the top.
That's how John Wayne would do it.
Mark in Memphis is offline
Old 09/18/07, 03:54 PM   #3
Baja71
Baja71's Avatar
Dallas, Texas
The quarter panel and the door seem fine, so does the door and the rocker reveal. I'll worry about the fenders last. I was looking at the backwards slant on the windshield which is not even and is closed at the top. It seems like the gap should be even all the way up. Yes? Is the slant on the windshield adjustable with either the dash bolts or the hard top leading edge bolts?
1971Stroppe Baja
Baja71 is offline
Old 09/18/07, 05:14 PM   #4
Dave
Check the body mounts that are right under your feet. You might have some body sagosis. If the floor boards are compromised by rust that cross member support looses its box structure and it will sag causing the door opening to get smaller at the top. I learned the hard way that you have to correct this before welding in new floor panels.
Dave is offline
Old 09/18/07, 05:25 PM   #5
Baja71
Baja71's Avatar
Dallas, Texas
No rust, but the body mounts are original. I have some poly ones standing by for the frame off, soon.
I found no way to move the top forward as the posts in the back were forward in the holes and pretty solidly bolted in place. Not much wiggle room. Also, there are what look like locating pins on the bedrails?
At any rate, the top seemed to be positioned correctly. I loosened the header bolts on top of the windshield and pushed forward on the very top of the windshield frame as I tightened the corner bolt. Once on each side. That gave me a better reveal on the top of both sides. The driver's door closes easier, but not without some effort. I think both door posts are slightly high but it looks like I need an impact driver to loosen those big screws.
I had the whole hardtop unbolted. If I'd have had a hoist, it would be hanging from the ceiling right now!
1971Stroppe Baja
Baja71 is offline
Old 09/18/07, 05:30 PM   #6
Dave
Try putting a couple of floor jacks under the body on the cross members as far out as possible. Put a little force them and see it the openings square up. Don't go nuts and bend anything. Measure the opening width top and bottem between front and rear quarters.
Dave is offline
Old 09/19/07, 08:08 AM   #7
Baja71
Baja71's Avatar
Dallas, Texas
Hey Dave, thanks for the response. When closed, the reveals on the door body itself are good & square to the quarter panel, rocker, fenders, even the hard top, so that just left the slope of the windshield to deal with. The windshield slope did not follow parallel to the door window frames when the doors were closed. I pushed the windshield forward, now I think if I adjust the door posts, I will be fine until I replace the hinges. I need to go out and buy an impact driver, I think, to loosen the door posts.
1971Stroppe Baja
Baja71 is offline
Old 09/20/07, 09:12 PM   #8
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
God help you!
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 09/21/07, 06:59 AM   #9
Baja71
Baja71's Avatar
Dallas, Texas
Originally Posted by blubuckaroo View Post
God help you!
um...thanks? I.....guess....?
1971Stroppe Baja
Baja71 is offline
Old 09/21/07, 09:15 AM   #10
trailpsycho
trailpsycho's Avatar
Indianapolis
What you may want to consider, if you have a front cage, is to use some shackles or other means to gusset the windshield to the front upper tube. In your case, it would need to go back (toward the front) probably less than 1/8" to fix the gap issue you have. If your fenders are square with the door...the sag is either in your cowl or your hinge...that is, if I understand your lack-o-gap between the windshield and the upper door frame. Keep in mind, it is a almost 40 yo truck...things sag and besides, they never fit perfect from the factory.
trailpsycho is offline
Old 09/21/07, 01:06 PM   #11
Boring66
Boring66's Avatar
"220-221 What ever it takes"
Boring, Oregon
I have the same problem on my 66 and to me it seems more like the upper door frame is the problem. Check the reveal at the latch side between the door frame and the top to see if they are parallel.
My cousin had one just like that----but his was better
Boring66 is offline
Old 09/21/07, 07:45 PM   #12
Baja71
Baja71's Avatar
Dallas, Texas
They are. Really, everything was in line except the windshield when the doors are closed and latched.
Now, I know the hinges are worn, but I was going to cheat by lowering the striker plate a touch until I get the nerve up to remove the hinges and rebuild them. I'm just dreading ripping a head off the hinge bolt and having to torch the paint.
1971Stroppe Baja
Baja71 is offline
Old 09/21/07, 07:50 PM   #13
Baja71
Baja71's Avatar
Dallas, Texas
It's got the Stroppe Deluxe bar (without a front cage). I loosened the header bolts on the hard top/windshield, pushed the top of the windshield forward and re-tightened the bolts. I may be OK. Maybe that bottom rubber seal is squished too much. I think it's original.
1971Stroppe Baja
Baja71 is offline
Old 09/22/07, 10:40 AM   #14
blubuckaroo
Grease Monkey
Ridgefield WA
I'm not being sarcastic! What I ment was that adjusting these doors can be a royal pain! I can think of a lot of more pleasant tasks.
What i've done is to put the hinges and strikers on and hang the door with all the bolts semi-tight. Use a mallat to adjust the hinges and striker to work properly then tighten everything up. A floor jack and a block of wood is handy to force the door up and make small adjustments. Some obstacles to look out for are worn out body mounts and the wrong thickness of top & door gaskets.
Old 09/22/07, 11:18 AM   #15
Baja71
Baja71's Avatar
Dallas, Texas
I knew what you meant! That's why I'm on here gathering information instead of sweating and cussing in the garage.
1971Stroppe Baja
Baja71 is offline
Thread Tools
Page generated in 0.30202 seconds with 54 queries
