Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/21/07, 11:47 AM   #1
tbuhrman67
tbuhrman67's Avatar
Council Bluffs IA
Cleaning out an old gas tank
i have a 67 bronco and i need to clean the rust and sediment out of the main gas tank. what is the best way of doing that? Doing it yourself or taking it to a radiator shop.
tbuhrman67 is offline
Old 12/21/07, 12:58 PM   #2
Chief Master Sergeant
Retired U.S. Air Force
Chief Master Sergeant's Avatar
The Green Machine
Spokane, Washington
To save you some heartache, try using the search function to locate your answer. What I did was take it to a radiator shop and had it boiled out, but there are much easier ways I am told. Someone mentioned putting marbles in the tank and shaking it to break loose any rust. I'm too lazy for that and it came back very clean from the radiator shop, so I'm happy. I painted the thing with POR 15 when they were done with it and it looks new. I hope this helps.
1972, 302, NP435, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, Hydroboost, WH 2 1/2" Suspension Lift
Chief Master Sergeant is offline
Old 12/22/07, 07:30 PM   #3
67ster
Broncos Rule!
I had a tank that sat for several seasons and the pickup became clogged with rust and debris . I used a 5' length of chain and some rust remover to get most of it loosened up. I then took it in and had it boiled out at a radiator shop . I used a sealer afterwards and so far it has held up .
67ster is offline
Old 12/22/07, 11:59 PM   #4
Project_bronco
Project_bronco's Avatar
"I'm a man, but I can change, if I have to, I guess." -Red Green
Cottonwood, CA
You can also use pea gravel and shake/roll it around in there real well. My dad did that to a gas tank on an old Oliver tractor we used to have and it worked real well.
1974 Bronco: 302 (RV cam, rebuilt Holley 4 barrel, headers, MSD ignition and distributor), C4, 3.5" James Duff lift, 33" bfg muds, Mickey Thomson Classic Lockers, 23 gallon rear tank. A work in progress.
Project_bronco is offline
Old 12/23/07, 09:54 AM   #5
Worth
Newbie
Cape Cod , Mass.
eBay: acrad
I use loose nuts and bolts, and some diesel fuel. Add contents and shake, rattle and roll. Works pretty good. Cleans the nuts and bolts up at the same time. :-)
Worth is offline
Old 12/25/07, 03:12 PM   #6
tml
tml's Avatar
Ontario, Canada
I used a chain aswell then blew out and sucked the debris from the tank.
76,68,73,66,69 Mach1
tml is offline
Thread Tools
Page generated in 0.40581 seconds with 56 queries
