Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 01/19/08, 04:26 PM   #1
Bronco_Rider
Bronco_Rider's Avatar
Brentwood, Ca
turn signal wiring Need wiring color lay out
The plug for the turn signal wires is missing on my 71 The steering column has just been replaced.
There is a fin on the top right of the main harness plastic male plug.
View is from the back of the signal wire plug, fin up or fin slot up at right
From left to right, I need the color sequence of wires on the top row
From left to right, I need the color sequence of wires on the bottom row
Any help would be appreciated
If any one has a plug available I would like to purchase it
Larry
71 Bronco with: 450 HP LS6 454, 700R4, 4 speed automatic, gear driven NP205, Limited slips, Quad Shocks, PS, Disc brakes, 33-12.50R 17 Mud tires on 17 x 9 Aluminum wheels, Full roll cage, Corvette seats, with full width running gear
Bronco_Rider is offline
Old 01/19/08, 04:38 PM   #2
66ALRIDE
I'm back!
66ALRIDE's Avatar
Cross threading is stronger then Loctite.
Dothan, AL
Maybe this help http://seabiscuit68.tripod.com/
Initial success or total failure...............
Facebook
Videos
1974 Bronco Build on Photobucket 75 Bronco Build Photobucket
66ALRIDE is offline
Old 01/20/08, 01:12 AM   #3
Bronco_Rider
Brentwood, Ca
signal switch wiring
A problem I see is the 71 shows a 6 pin plug. The truck has a 8 pin plug
there are colors not shown.
Thanks for the lead
Larry
Old 01/20/08, 08:13 AM   #4
SeaBiscuit68
SeaBiscuit68's Avatar
Tacoma Wa
'71 should have a 6 pin and a 2 pin plug. You say the column has been replaced, what is the column from? Is your connector a curved shape? Does your new column have a hazard flasher switch?
Early Bronco Electrical Diagrams In Color!:
SeaBiscuit68 is offline
Old 01/20/08, 10:22 AM   #5
rjlougee
rjlougee's Avatar
Anything worth doing is worth overdoing!!
Falcon, CO
eBay: RJLougee
I added a later model, tilt column to my EB and wrote up what wire colors were used for each circuit. It's a table about here:
http://pages.prodigy.net/rjlougee/tips.htm#ts
HTH, Joe
'06 Buggy, Explorer 5.0, manual/reverse C-6, Atlas 4-spd, 39.5" Krawlers, etc...
'71, 408 Stroker, AOD, Atlas, D60 and True Hi-9, 40" MT/Rs, etc...
'83 BB MAF 351W, ZF, SAS, etc...
rjlougee is offline
Old 01/20/08, 10:28 AM   #6
Bronco_Rider
Brentwood, Ca
I took a column out of a 73-75 F-100 and installed a 71 bronco signal assembly. Hazard switch is still in the dash.
Main harness has the 8 pin, rectangular plug
There is no plug on the signal wires. Still searching
The original column had an extension welded to the shaft and was a disaster waiting to happen.
Good questions. Appreciate the imput
Any idea which yr Bronco had the 8 pin?
Larry
Old 01/20/08, 10:45 AM   #7
Bronco_Rider
Brentwood, Ca
Hey Joe,
That was great information. I copied it and added it to my Bronco file
Larry
Old 01/21/08, 05:36 AM   #8
SeaBiscuit68
Tacoma Wa
I have no idea which year used a rectangle 8 pin plug. I've only seen the 6/2 and the curved one.
These are the Early Bronco steering column colors:
Designation----------------Early-----------Mid Years-------Late
Hazard Flasher-------------N/A ------------White/Red-------White/Red
Turn Flasher---------------Blue------------Blue------------Blue
Brake Switch---------------Purple----------Red/Black-------Red/Black
Left front turn signal-----Green/White-----Green/White-----Green/white
Right front turn signal----White/Blue------White/Blue------White/Blue
Left rear Turn/Brake-------Green/Orange----Green-----------Green
Right rear Turn/Brake------Orange/Blue-----Yellow/Black----Yellow/Black
Horn Relay-----------------Yellow----------Yellow----------Yellow
Horns----------------------Blue/Yellow-----Blue/Yellow-----Blue/Yellow
(I think after '74 they moved the emergency flasher switch up to the column,
so this accounts for the extra wire.)
Thread Tools
Page generated in 0.30357 seconds with 56 queries
