Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 01/26/08, 12:29 PM   #1
JoseyWales
JoseyWales's Avatar
Chattanooga, TN
Question Motorcraft 2-barrel carb... F-2 or 2100-D
Hi all. I am going to rebuild my original Motorcraft 2-barrel carb. When I started looking at the instructions from the rebuild kit, it appears mine is a F-2 carburetor. I have read the 2100 carb does well off-road on inclines and such, but I haven't read anything about the F-2. Is it as good as the 2100 carb?
1975 Bronco. 5.0L, Motorcraft 2-bbl Carb, MSD, C4 wide ratio, 4.11:1 TrueTracs, Dana 20, 33x10.50 BFG MT, TRO, 2.5" lift
"All those hifalutin society people... I don't care if they don't understand!"
JoseyWales is offline
Old 01/26/08, 09:53 PM   #2
broncomitch
broncomitch's Avatar
dont be a sheep in a jeep!
west jordan, utah
carb qustion
i been told yes. but i took mine off for a 4bbl and put a offroad kit in it.
broncomitch is offline
Old 01/26/08, 10:02 PM   #3
charliecorbell
Newbie
Huntsville
Just rebuilt a 2150 2BBL. It is running very lean and having trouble getting it to adjust. Plus when I have not run it in a couple of days, I thing the needle valve or float sticks and floods to the intake manifold. Any suggestions.
Also looking for vacuum diagrams for '73 302 standard. Want to return everything stock. I have the charcoal canister. I would love to see pictures.
1. Choke vacuum- temp regulated, passenger side.
2. rear engine tree
3. rear passenger side of carb.
charliecorbell is offline
Old 01/27/08, 10:39 PM   #4
PaulS
Performance C4s
Greater Seattle area
The year of the vehicle that it came off is very important. 1971 and later have mods to the accelerator pump and jets that are two sizes lean for best street use. Those were the original emission carbs. there is a brass plug with a hole in it in the accelerator pump well - it needs to be pluged. The shooters are fine but you also need to lengthen the stroke to the maximum setting.
After replacing the jets, soldering the hole shut and lengthening the stroke (put the rod on the inside hole of the lever on the pump and the outside hole on the throttle end) on the pump you have a carb that is easier to adjust and will run smoother under all conditions.
mechanic of 35 years specializing in Performance C4s.
Used to fix cars - now I fix people
PaulS is offline
Old 01/27/08, 11:08 PM   #5
Baja71
Baja71's Avatar
Dallas, Texas
I just rebuilt my 1971 2100 and I'm not sure what you're referring to as a brass plug. Also, before I started the rebuild, my carb was set up using the OUTSIDE hole on the acc. pump arm and hole #4 on the throttle end. All docs told me it should be the INSIDE arm hole and hole #3. Can you clarify?
1971Stroppe Baja
My build thread: http://classicbroncos.com/forums/sho...d.php?t=122019
Baja71 is offline
Old 01/27/08, 11:27 PM   #6
PaulS
Performance C4s
When you take the accelerator pump off the carb you have the check valve staring you in the face. Just below that orange silicone flapper check valve there is a hole that goes back into the fuel well. In that hole there is a brass plug (unless you are unlucky enough to get one with an aluminum plug) with a small hole in it. When the accelerator pump tries to push fuel up through the shooters, part of that fuel goes through the hole and back into the fuel bowl. Plugging the hole with a bit of solder increases the flow to the shooters.
If you have the aluminum plug you will have to tap it out with a punch and then use a lead rivet to plug the remaining hole.
To increase the length of the fuel delivery you want it on the hole farthest from the throttle shaft at that end and on the pump arm you want it in the closest hole toward the pivot of the arm. So, if hole #4 is farther from the throttle shaft it is better to place the link there. Most of the emission carbs have the link set on the outside hole of the lever at the pump. You can get a longer fuel shot if it is placed on the inner hole.
If you notice a surge (rocking back and forth) when cruising at around 50 to 60 mph or that it takes a great deal of throttle to begin to accelerate from 50 to 60 MPH and then it seems to continue after you have let up on the throttle to cruise then your carb has the lean jets for emission control. Just put a pair of jets in that are 2 sizes larger than the ones in the carb. Presto! You are back to 1969 specs.... in addition to the jet change the accelerator pump mods will also return the rest of the carb back to 1969 specs. It will run smooth and you will notice a marked increase in power and drivability.
You could, of course, just buy a rebuilt carb for any midsize 1969 car with a 302 and get the same thing. I'm cheap, I would rather make the mods than pay for a used carb that may or may not have been built by a professional.
PaulS is offline
Thread Tools
Page generated in 0.39959 seconds with 56 queries
