BlazinCopper
Has anyone used the rear disc brake setup off of a 96-01 Explorer. The caliper bracket will work if I drill the center hole out a little bit, but I don't know what rotor will fit. Needs to be a 5 x 5.5 lug, 11" diameter rotor. Has anyone done this conversion or have any ideas on what rotor I could use?
Also, I read that if you use the explorer rotors and drill them out that they will not work with stock axles, that you have to have new axles with a 2.5" backspacing so the rotor will fit all the way on. Can you use stock axles if put a 1/2" spacer behind the rotor?
