Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 07/26/08, 10:02 PM   #1
rsharpnm
rsharpnm's Avatar
"I'd rather have a bottle in front of me than a frontal lobotomy"
Las Cruces
Pic request: 37's & a 3.5" lift
I was looking at my truck today, which has 35's and a 3.5" lift, and I was thinking if I cut the fenders to the body line 37's would fit.
So I would like to see if anyone else is running 37's with a 3.5" lift and NO BODY LIFT
'75 Bronco- 3.5" Super Lift, 35" Goodyear MTR, NP 435, Detroit rear, 4.11's, 9500# winch, Taurus fan, Carter 4070 fuel pump, Magnaflow exhaust
'84 Bronco II- 4" Skyjacker Class II lift, Bushwacker flares, 35" M/T's, Autolite 2100 carb, 3 core radiator, 4-pt roll cage, 8.8" rear
rsharpnm is offline
Old 07/26/08, 10:05 PM   #2
Madgyver
Bronco Madman
Madgyver's Avatar
RADIO FLYER ROCKS
Honolulu,Hawaii
Believe me it will fit if you center it and cut flares up to body line.....
Next build I will do just that.... Low COG with big meats....
Originally Posted by br0nc0xrapt0r View Post
your so full of shit your eyes are brown.
Haha.
Madgyver is offline
Old 07/27/08, 07:21 AM   #3
fdezone
fdezone's Avatar
Fredericksburg, VA
You'll have to modify the inner fenders as well if you're planning on stuffing 'em.
fdezone is offline
Old 07/27/08, 07:50 AM   #4
bax
bax's Avatar
smokin 37's
Melbourne.
I have 37 and a 3 1/2'' lift but I also have a body lift of 3 inches. So that counts me out.
1971 U15 Ol'blue 5.0/4r70w/205/ 4,11. 1968 U15 - EFI 408C/C6/205/4.88/37's/hi9/ARB's/hydro-boost/full cage/4wdisk/PS/powerasswipe/bla-bla-bla!
bax is offline
Old 07/27/08, 08:22 AM   #5
Socal Tom
Socal Tom's Avatar
Stop calling me a liberal
San Diego, CA
eBay: tlgreen2
I've got 35s on a 3 1/3 inch lift. The fronts are probably ok, but the rears rub on the inner fenders. It will take more than cutting to the body line IMO.
Tom
Former Bronco Owner
Socal Tom is offline
Old 07/27/08, 08:54 AM   #6
br0nc0xrapt0r
Loves pickles
br0nc0xrapt0r's Avatar
Fueled by Hate, caffeine, and sometimes whiskey.
Kent City MI
check out cages early bronco.
http://www.cageoffroad.com/ford2.asp
SEMPER FIDELIS
69 Exxon Valdez, 37" locked front and rear, Daily driver.
http://classicbroncos.com/forums/sho...d.php?t=163762
WTB pulley cover for 1959 Homelite 9-23
br0nc0xrapt0r is offline
Old 07/27/08, 09:54 AM   #7
fdezone
fdezone's Avatar
Fredericksburg, VA
"This '69 Bronco has our 3.5" extreme travel suspension lift combined with a 2" body lift. Oh and a LOT of fender trimming to clear 40x13.50x17" Goodyear MTR tires."
http://www.cageoffroad.com/images/photos/img10.jpg
http://www.cageoffroad.com/images/photos/img4.jpg
I would imagine they also lengthened the wheelbase, swapped in some 1-ton units, hydro-assist steering, etc. It doesn't really appear like it in the pics though. She does look bad arse.
fdezone is offline
Old 07/27/08, 08:25 PM   #8
ProjectBronco70
ProjectBronco70's Avatar
Tennessee sounds good to me
Tennessee
37's 3.5 inch lift and 1 inch body lift. I think it will work. I may just have to trim a little more of the inner fender than I did for the 35's.
1973 Bronco....work in progress.
ProjectBronco70 is offline
Old 07/28/08, 10:06 AM   #9
rsharpnm
rsharpnm's Avatar
Las Cruces
Thanks for all the responses. My Bronco actually has ~4.5" of lift in the rear, so I am more worried about the front.
I have seen the cage Bronco, and it's cool, but that is a bit bigger than I want to go , thanks though.
ProjectBronco70, your truck looks good, but I would really like to see an actual picture of a bronco on 37's with only 3.5" of lift. Thanks though.
I guess what I'm really wondering is if I can get 37's of with just more cutting, and not have to reconstruct custom inner fenders.
rsharpnm is offline
Old 07/28/08, 03:43 PM   #10
Gummi Bear
Gummi Bear's Avatar
Acting your age takes some getting used to...
Arlington, Texas
It'll roll down the road OK, but you'll catch the leading and trailing edges of the wheelwells front and rear at full stuff on the trail. It sounds horrible, and will cut the lugs. I hammered mine flat at one point, but they still drug. The tire's just too darned big for that little wheelwell. Anything larger than a 33 will catch at full stuff if you don't have some wacky long bumpstops.
I ran 38's with a 2" BL and stock springs in the rear, and some buggered up 3-1/2"'s in the front (sat pretty level though, go figure)
(\__/)
(")_(")
Gummi Bear is online now
Old 07/28/08, 03:51 PM   #11
bax
bax's Avatar
smokin 37's
Melbourne.
No cutting needed. 37's with a 3 1/2'' lift. Ok so there is a 3'' body lift too.
bax is offline
Old 07/28/08, 09:50 PM   #12
rsharpnm
rsharpnm's Avatar
Las Cruces
Originally Posted by bax View Post
No cutting needed...
I think you're stretching the truth there I've seen what you did to your rear quarters, that there is a faux uncut
rsharpnm is offline
Old 07/29/08, 02:19 PM   #13
joser
joser's Avatar
Life, Liberty, and the pursuit of Happy Hour!
Chesterfield, MI
3.5" suspension lift, 2" body lift, and a bit of fender trimming. I also removed my inner fenders. These are 36 X 13.5 X 15 IROCs that measure like 37" tires. They are 36.8" in diameter.
I also have 3" backspacing on my rims. Except rubbing on the radius arms at full lock, I do not rub.
'70, 351W, Holley TA, C4, Terra Lows, 3.5" susp & 2" body lift, 36X13.5 IROKs, D44, Detroits & 4.56 gears F & R, Proto Fab family cage & F&R Bumpers, Racecraft seats F & R, Painless Harness, and custom Rock Skis.
joser is offline
Old 07/29/08, 06:08 PM   #14
Recko555
Recko555's Avatar
Northeast Iowa
Here is what you are ACTUALLY looking for. 37s, 3.5" suspension, no body lift.
http://share.shutterfly.com/action/w...M2LCYA&notag=1
1974, EFI 302, 3.5" suspension lift, power disc brakes, 37s, COR cage/tie-ins, rocksolid bumpers front/rear, warflares front/rear, 4.30 gears, D44 Ox, 4340 axles and Yukon joints, 9" 31 spline detroit, and much more........
Recko555 is offline
Old 07/29/08, 10:02 PM   #15
rsharpnm
rsharpnm's Avatar
Las Cruces
Sweet! That looks good, I was beginning to think I would never find what I was looking for!
Thank you sir!
rsharpnm is offline
Thread Tools
Page generated in 0.32614 seconds with 59 queries
