Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 08/27/08, 10:29 AM   #1
mountaincat68
Newbie
8 lug Ford 9 inch?
Hey everyone,
I am currently in the planing stages of my 66 bronco build and I have a question. My buddy has a HP D44 out of a 79 F-250 that he is going to give me, so I plan on narrowing that and putting it under the bronco, I would like to keep the heavy duty disk brakes from the F-250 but I don't want to run two different sets of wheels. So my question is, is there any way to make my 9 in rear a 8 lug pattern? I am not afraid of some custom work to the axle I will already have to put the big bearing ends on.
mountaincat68 is offline
Old 08/27/08, 10:30 AM   #2
Clint
redneck
Grand Junction, CO
Originally Posted by mountaincat68 View Post
Hey everyone,
I was not able to find a way when I did the 60 in mine. I talked with Currie and Dutchman and both said no.
Clint is offline
Old 08/27/08, 12:59 PM   #3
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
I don't see why you couldn't do it like a 609 hybrid. Get some spindels and brakes from a full floater then get the custom axles to span the gap.
Semi floating 8 lug would be harder. I see no reason they could not do an 8 lug axle, but getting brakes could be chalanging. Probably the best bet if you could pull that off would be 8 lug rotors and then rig your own caliper bracket, and loose the park brake at the same time most likely.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 08/27/08, 01:37 PM   #4
Bronco73
Bronco73's Avatar
Cape Coral, FL
Ford made a an 8 lug 8.8 axle and it was not a FF axle! I have seen them with my own eyes. Came in the light duty F250 4x4 trucks and may have been in some 4x2 trucks. I've only seen them in the 4x4 trucks. Mid 80's or some where around there.
Bronco73 is offline
Old 08/27/08, 01:45 PM   #5
BUCKETOBOLTS
BUCKETOBOLTS's Avatar
...was born with nothing and still have most of it left...
Salisbury, NC
I've seen them too. Also seen SF D60's which are 8 lug.
The only problem I can see with a SF 9" with 8 lugs would be brakes. You would have to do some sort of disc conversion. Stock drums are not large enough to accept the large flange of the 8 lug axle.
'72 Explorer, TBA...
'76 F250 2wd, 390, NP435, 4.10's...aka Brutus
CarolinaBroncosMember
BUCKETOBOLTS is offline
Old 08/27/08, 01:47 PM   #6
welndmn
welndmn's Avatar
Well Done Man!
Concord, CA
No one will make you a SF 9 lug 9 inch axle.
You could cut off the spindles from a dana 60. 70 or 14 bolt and weld them on the 9 inch.
But then, why not just swap the whole rear axle under...
Mark, 71 bronco with loads of go fast parts held back by a 200hp engine.
42 inch marshmallows.
welndmn is offline
Old 08/27/08, 03:01 PM   #7
broncomitch
broncomitch's Avatar
dont be a sheep in a jeep!
west jordan, utah
i agree with that. but if your going biger axle in the back i would use a 14 bolt i heir there stronger then a 70 and the disc brake conversion is super super easy.
1971 bronco sport,mild built 351w,c6,strong box,np205,HP Dana60,srw 14bolt,disc's front and rear,16"rock coil overs,H1's & 44" tires,4.10's,3link front,56" springs,ez wiring,TBI injection,
Build thread
http://classicbroncos.com/forums/sho...d.php?t=196087
broncomitch is offline
Old 08/27/08, 04:33 PM   #8
bludorbronc
central Iowa
Dare to be differant,cut the ends of the nine inch and weld on the 70 spindles,all ready 35 spline,buy the nodular center,daytona support, disc brake kit,shorten and respline the axles,don't forget to weld on the back brace for stength,when you cut housing,figure so both axles are same length. Now you have more ground clearance,lighter,and way expensive.And you can say I did it my way.
bludorbronc is offline
Old 08/27/08, 04:47 PM   #9
Crewwzin
Crewwzin's Avatar
If you cant fix it with a hammer, you have an electrical problem.
Freeport, Fl
I dont really have any thing to add to this other than I've never, NEVER seen a 9 lug axle.
(I know it was a typo....just ribbin ya!!)
1966 Wagon, '97 Explorer 5.0, M5R2 tranny, 3.5" lift, 35x12.50x17s....never ending build.
Crewwzin is offline
Old 08/27/08, 05:52 PM   #10
Adapt and overcome
Maricopa, AZ
But I have seen a Ford with a 7 lug wheels. Talk about a head scratching bastard. Light duty F250 in the late 90's. They continue the styling to this day with the 7 lug hubcaps (go look at the hubcaps on a new econoline!)
Old 08/27/08, 06:02 PM   #11
JWMcCrary
JWMcCrary's Avatar
Brandon-MS/Canton-OH
Yep. I own one. 99 F250 light duty 4X4
You can count them on the rear wheel in the pic.
In Memory of Michael Stark "Deep faith eliminates fear... on the trail"
"I have been upside down, backwards, on fire, faster than most people have ever gone and had one hell of a good time doing it" Don Garlits
"Yes, you can make it, follow my line" Gordon Bailie
JWMcCrary is offline
Old 08/27/08, 06:14 PM   #12
mr.n
The flange is the biggest issue.
A few years ago I called every axle manufacturer I could find. Never did find one that could make this axle if they wanted to. Mosser said they may have back in the day, but wouldn't today.
I've some ideas, but couldn't a bearing to fit.
My basic notes on Dana 44 and other Dana axles -> http://77cj.littlekeylime.com/web_rs44.html
mr.n is offline
Old 08/27/08, 08:36 PM   #13
76Broncofromhell
Bronco Totalitarian
76Broncofromhell's Avatar
Whiskey, the third leg in my triad of manliness
Campbell, CA
Agreed. Save yourself the time and find a 14 Bolt, D70, or 10.25" Sterling...in that respective order.
'70 Bronco - 408W
'45 Ford GPW - 351W
'84 Toyota - 5.0L HO
'84 FJ-60 - 5.0L HO
'13 Shelby GT500 - 5.8L
76Broncofromhell is offline
Old 08/27/08, 10:54 PM   #14
scsm76
scsm76's Avatar
NorCalBroncos.com
Shaver Lake, CA
Or you could just buy 5 x 5.5 to 8 x 6.5 wheel adapters.
A complete 14-bolt or Dana 70 would be cheaper though.
See all my recent upgrades here
69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, rear 4-link
scsm76 is offline
Old 08/28/08, 01:12 AM   #15
mountaincat68
Newbie
thanks alot guys, I guess I am stuck with either a new axle in the rear or convert my front to 5 lug.
How were the full floating d60s in the back of a 79 f250 I think my buddy has one of those too?
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.35175 seconds with 55 queries
